Stalling issue https://www.ausmini.com/forums/viewtopic.php?f=2&t=59800 |
Author: | mini-dunger [ Thu Dec 24, 2009 2:43 pm ] |
Post subject: | Stalling issue |
Hello all..... I have started taking my mini for small test drives around the block... and all is well until I turn right. I turn right and it stalls and takes a couple minutes to start again. I don't think its a starving issue because the pump gets really noisy when its low and I haven't heard a peep.... any ideas? |
Author: | drmini in aust [ Thu Dec 24, 2009 2:50 pm ] |
Low float level? What carby? |
Author: | mini-dunger [ Thu Dec 24, 2009 3:15 pm ] |
drmini in aust wrote: Low float level? What carby?
1 3/4 SU I was thinking that too......maybe to high? would that make it flood on turns? I will go have a look at it after |
Author: | mikkis37 [ Thu Dec 24, 2009 6:53 pm ] |
I had similiar issues. Turned out to be needle! But that would only be my thought! |
Author: | TheMiniMan [ Thu Dec 24, 2009 6:56 pm ] |
Just don`t turn right & problem is solved ![]() ok ok,,, sorry,,, couldn`t resist it ![]() most probably & commonly a float angle / level situation |
Author: | Morris 1100 [ Thu Dec 24, 2009 7:37 pm ] |
TheMiniMan wrote: Just don`t turn right & problem is solved
![]() ok ok,,, sorry,,, couldn`t resist it ![]() most probably & commonly a float angle / level situation I would also think it would be float level. ![]() But you can't overlook a hidden electrical problem with problems when cornering on particular way. It might be something silly like a loose wire on an electric fuel pump or a coil wire that shorts when cornering. ![]() |
Author: | TheMiniMan [ Thu Dec 24, 2009 7:44 pm ] |
Morris 1100 wrote: TheMiniMan wrote: Just don`t turn right & problem is solved ![]() ok ok,,, sorry,,, couldn`t resist it ![]() most probably & commonly a float angle / level situation I would also think it would be float level. ![]() But you can't overlook a hidden electrical problem with problems when cornering on particular way. It might be something silly like a loose wire on an electric fuel pump or a coil wire that shorts when cornering. ![]() totally agree & i was actually going to type all that too ,but it seemed to long ,,, & everyone knows i don`t like typing long responses ![]() |
Author: | Morris 1100 [ Thu Dec 24, 2009 7:47 pm ] |
TheMiniMan wrote: Morris 1100 wrote: TheMiniMan wrote: Just don`t turn right & problem is solved ![]() ok ok,,, sorry,,, couldn`t resist it ![]() most probably & commonly a float angle / level situation I would also think it would be float level. ![]() But you can't overlook a hidden electrical problem with problems when cornering on particular way. It might be something silly like a loose wire on an electric fuel pump or a coil wire that shorts when cornering. ![]() totally agree & i was actually going to type all that too ,but it seemed to long ,,, & everyone knows i don`t like typing long responses ![]() ![]() ![]() |
Author: | mini-dunger [ Thu Dec 24, 2009 10:39 pm ] |
thanks guys I will have a quick check of the power to the pump. I will then refer to my Mini texts and insure the float level is correct.... I never really gave it that much thought because I didn't think the float bowl would empty and refill "that" often, and the fact that fuel is drawn from the bottom of the bowl... I wont put that much thought into it and just fix it. thanks again eryone |
