Difference between Hydro and Dry top arms? https://www.ausmini.com/forums/viewtopic.php?f=2&t=59802 |
Author: | Minieleven11 [ Thu Dec 24, 2009 3:58 pm ] |
Post subject: | Difference between Hydro and Dry top arms? |
Hi guys just wondering what the difference between hydro and dry suspension top arms are? Cheers Jack |
Author: | GR [ Thu Dec 24, 2009 4:25 pm ] |
Hi Minieleven11 Where the ball and socket fit in the top arm this is closer to the ball joint, so if you fit these to a rubber cone it will make your spring rate harder, than the std arms, good for race cars Graham Russell |
Author: | Harley [ Thu Dec 24, 2009 4:35 pm ] |
Did hydro arms have stubs for shock absorber mounts? |
Author: | Morris 1100 [ Thu Dec 24, 2009 4:39 pm ] |
Harley wrote: Did hydro arms have stubs for shock absorber mounts?
The hydro arm has a bolt through the shock mount hole to fit the bump stop. |
Author: | GT mowog [ Thu Dec 24, 2009 5:27 pm ] |
They had a bolt to hold the bump stop on, however it was only 1/4" in diameter for the hydro arms. For standard shock mounts they need to be 3/8". Cheers. |
Author: | drmini in aust [ Thu Dec 24, 2009 6:16 pm ] |
GT mowog wrote: Harley wrote: Did hydro arms have stubs for shock absorber mounts? They had a bolt to hold the bump stop on, however it was only 1/4" in diameter for the hydro arms. For standard shock mounts they need to be 3/8". Cheers. They are bloody hard to drill, on the car. Those arms are tuff stuff. I used M8x100 Grade 12 Unbrako capscrews instead, and bushed the lower shock bushes to 8mm. Been fine the last 10 years or so. ![]() see http://www.ausmini.com/forums/viewtopic.php?t=12180 |
Author: | GR [ Thu Dec 24, 2009 6:19 pm ] |
Hi We just run a 5/16 high tensile bolt in our race cars no problems,drill it out with a hand drill ![]() Graham Russell |
Author: | TheMiniMan [ Thu Dec 24, 2009 6:40 pm ] |
GT mowog wrote: Harley wrote: Did hydro arms have stubs for shock absorber mounts? They had a bolt to hold the bump stop on, however it was only 1/4" in diameter for the hydro arms. For standard shock mounts they need to be 3/8". Cheers. Nah, they`re 5/16ths std drill to 3/8 for shocky fitment & yeah right GR,,, you can do my next set with a hand drill,,, i`ll sit back eating some wagon wheels & sipping on my cup(s) of tea watching you ![]() ![]() ![]() crickey , next thing you`ll say is that mini crown wheels are soft & can cut with a kitchen knife yeah>??? ![]() ![]() ![]() Merry Christmas |
Author: | GR [ Thu Dec 24, 2009 7:56 pm ] |
Hi Matt Ya gota learn to sharpen drills matt, there not hard matt a little tough may be but there not that hard. Yes i can machine the crown wheels out but not with the kitchen knife i use that to wedge cranks ![]() Graham |
Author: | TheMiniMan [ Thu Dec 24, 2009 11:11 pm ] |
oh!!! do drill bits need to be sharp??? Damn,,, i thought there was "something" i was supposed to do ![]() & as for wedging cranks, --> i just get my girlfriend to sit on them & tow them on a rope behind the V8 kombi on the concreat footpath... isn`t that how it`s supposed to be done??? I had to machine the crown wheel teeth off to fit my motorbike sprocket on for my R1 hillclimb special,,, Unkle Bruce Ayers wasn`t happy with me wearing out/breaking a few of his ceramic tips ![]() ![]() As for my CNC light-flywheels,,, well,,, CNC means "Chunks of Nastey Crap" doesn`t it??? ![]() |
