It is currently Sun Aug 03, 2025 6:26 am
 Post subject: engine rattle
PostPosted: Fri Jan 08, 2010 1:54 pm
My mini has a chain rattling sound.
The rattling sound comes in and gets quite loud when you accelerate normally and when accelerating from coasting.
There is no rattling sound when coasting or when accelerating hard from coasting .
There is no rattling sound when idling or revving the motor while stationery.
I have checked the grill,bonnet and radiator shroud without success.
Any ideas?
http://smg.photobucket.com/albums/v515/chasg/
PostPosted: Fri Jan 08, 2010 2:01 pm
Sounds like the timing chain.
Is the engine and 'A' or 'A+' ?
How many miles since service or rebuild?
Engine size? - 998, 1098, 1275 or later model from Rover etc?
Dave K.
PostPosted: Fri Jan 08, 2010 4:11 pm
Idler gears ?????
My Guess !
1964 Grp Nb Cooper S
1976 911 3.6 Circuit Car
1969 911T Grp Sb Historic Racer
2009 LC200 V8 TDI.... 660nm..
2011 Golf VI, TSI
PostPosted: Fri Jan 08, 2010 5:07 pm
how about top engine steady bush's and engine mounts, motor rocking under load and something touching bulk head. If its the timing chain you can hearit rattling while idling.
PostPosted: Fri Jan 08, 2010 5:14 pm
Id agree with engine/gearbox steadies. Are you sure the rattle isnt in your gearstick? If its a remote change its very common.
Simplify and add lightness
PostPosted: Fri Jan 08, 2010 5:32 pm
timing chain would rattle when stationary and revving the motor.
engine steadys wouldnt be enough play to cause a large rattle on acceleration.
im going to take a guess at CV joints. As they get worse they will rattle more.
PostPosted: Fri Jan 08, 2010 5:41 pm
Could also be a timing issue . . . engine "pinking" (aka. pinging)
PostPosted: Fri Jan 08, 2010 8:59 pm
I think you are on the money Ballistic, it can be a decieving sound !
PostPosted: Fri Jan 08, 2010 9:55 pm
Good one Scott, I would say your correct.
Check the timing and make sure its not over advancing and use better fuel, std unleaded (91) isnt good for a mini engine, I reccomend using premium (98). These two suggestions will hopefully fix your problem.
Have a Nice Day.
