It is currently Wed Aug 06, 2025 9:28 am
PostPosted: Thu Jan 07, 2010 1:10 pm
Has anybody got a blueprint or plan for making a keyless entry for a mini boot? Probably mechanical via a pull cable rather than electrical would be preferred but I'm open to ideas.
I want to get rid of the handle like this:
https://www.plminishop.com/product-SB002.html
I also want to put internal hinges thereby losing the hinges as well. This is a bit tricky coz the hinges have to hinge up and over. Any ideas?
Regards,
Mike
"He who dies with the most toys wins."
PostPosted: Thu Jan 07, 2010 1:52 pm
For the hinges, there's some discussion here:
http://www.ausmini.com/forums/viewtopic.php?t=52847&highlight=boot+hinge
PostPosted: Thu Jan 07, 2010 1:56 pm
beat me to it
PostPosted: Thu Jan 07, 2010 2:23 pm
you can buy keyless entry kits with a ir keyring, click the keychain and the doors pop an inch and you can then open them. If you go with a pull chain then how are you planning on locking the boot.
PostPosted: Thu Jan 07, 2010 2:55 pm
Mien
That picture looks horrible.......like it's got a big bum.
PostPosted: Thu Jan 07, 2010 4:04 pm
+1
 Post subject: Boot hinges
PostPosted: Thu Jan 07, 2010 4:16 pm
Earlier post is excellent. Just what I was thinking of doing.
However, it will need springs to keep the bottom of the boot closed or they will just open at the bottom when the boot is closed.
Off to drink some engineering initiative fluid (beer) so I can have a think about it.... :D
Looking for lock ideas still...
Regards,
Mike
PostPosted: Thu Jan 07, 2010 5:13 pm
Have a look at Trickys El Gato project. He fitted a remote release mechanism from a Civic http://www.ausmini.com/forums/viewtopic.php?p=351298&highlight=functioning#351298. An electric boot cable release mechanism was used, but the mounting idea woud be the same for a manual cable.
In combination with struts installed (http://www.ausmini.com/forums/viewtopic.php?p=693180), it would be a clean solution and a very smooth looking Mini bum.
-Alan
 Post subject: Re: Boot hinges
PostPosted: Thu Jan 07, 2010 6:03 pm
Why? If there's no handle...
PostPosted: Thu Jan 07, 2010 6:07 pm
Even if there's no handle, you still need to be able to keep it shut/locked :)
-Alan
