It is currently Sat Aug 02, 2025 1:30 pm
 Post subject: Fluid Change
PostPosted: Fri Jan 08, 2010 10:15 am
Ive just been thinking this Feb will mark 7yrs since my car has been on the road and has just recently ticked over 10 thousand miles. I think I should probably flush and change the brake/clutch fluid?
Is the silicone based stuff really that much better? Im led to believe its not as hygroscopic as standard fluid, so would probably be better to use in my situation?
Thoughts/ideas?
PostPosted: Fri Jan 08, 2010 10:19 am
Brake fluid should be replaced every 2 years regardless of milage.
Clutch is easy whilst you're in there.
Maybe do coolant too.
And oil.
:D
PostPosted: Fri Jan 08, 2010 11:39 am
Not simply a matter of switching fluids. I think you have to renew all the seals & rubbers as well. Plus the cost is exxy. Personally, I think its easier, cheaper & simpler to do more regular changes with the ordinary stuff, even though its a messy job. And I hate the feel of the stuff.
PostPosted: Fri Jan 08, 2010 4:15 pm
Hmmmm, maybe Ill just go with a good Dot 4/5 fluid then....
