Fuel filter https://www.ausmini.com/forums/viewtopic.php?f=2&t=60114 |
Author: | ministar [ Fri Jan 08, 2010 1:17 pm ] |
Post subject: | Fuel filter |
Just wondering how to relieve the fuel system pressure in order to change fuel filter. Any other advice too. |
Author: | Hanra [ Fri Jan 08, 2010 1:18 pm ] |
Is your car EFI? |
Author: | ministar [ Fri Jan 08, 2010 1:26 pm ] |
Na its a Leyland Mini Clubman. |
Author: | Hanra [ Fri Jan 08, 2010 1:29 pm ] |
Then you have nothing to worry about then. Where is your filter located? |
Author: | ministar [ Fri Jan 08, 2010 1:45 pm ] |
Just at the back of the valve cover |
Author: | Hanra [ Fri Jan 08, 2010 1:50 pm ] |
Easiest job in the world then!!! Go and get stuck into it then! |
Author: | ministar [ Fri Jan 08, 2010 1:52 pm ] |
Yeah I thought it would be simple. thanks for the help. cheers |
Author: | mini_mad_matt [ Sat Jan 09, 2010 11:38 pm ] |
Just a note if people want to do it on an efi car, if it has a fuel pump relay, then take it out and run the car till it stalls. Gets rid of the pressure in the lines so you don't get a spray of fuel when you take a hose off. |
