It is currently Tue Aug 05, 2025 7:17 pm
PostPosted: Fri Jan 08, 2010 10:24 pm
Hi everyone i have just bought some new red dot rubber cones from mini sport. I put them in the subframe the other day and i have noticed that the new cones are alot higher than the old ones when i put them in i had to remove the bump stop under the top arm as i didnt have a cone compressor. I addjusted my hilos as far down as i could to fit them, i have put it all back together and i cant put the bump stops back in because there is only about a 5 mm gap bettween the top arm and the sub frame is this normal or will i have to take a bit off the hilos so i can get a bit more adjustment as the car will be sitting high as it is?
Thanks Jack
PostPosted: Fri Jan 08, 2010 10:32 pm
Tomboss Breweros
I'd leave it for a while to let the cones settle in then see if you can fit them back in a month.
kimini wrote:
Jimmyinamini wrote:
Users browsing this forum: BBY755 and 79 guests
