It is currently Sat Jul 26, 2025 12:27 am
 Post subject: HIF Carb
PostPosted: Thu Apr 07, 2005 11:24 am
Which bit of the carb do I measure to determine its size?
PostPosted: Thu Apr 07, 2005 11:42 am
the bore of the carb being where the air passes through
100% Pure A Series Turbo
PostPosted: Thu Apr 07, 2005 12:18 pm
The diametre of the hole on the side that bolts to the manifold, not the air filter side. 8)
PostPosted: Thu Apr 07, 2005 2:25 pm
Typical. Spose I better take the manifold off then and check it.
PostPosted: Thu Apr 07, 2005 5:12 pm
1 1/5 have one bolt on top and HIF44 have all four with no exposed float bowl as it under the card :D
