hi guys,
i'm currently re-wiring a friend's '65 morris mini deluxe with an EZ-wiring 12 circuit harness, and so far so good but i have a couple of specific questions which relate to a few electrical components. i do have a copy of the factory wiring diagram but things would go much quicker if i could get some help with these things. any help would be greatly appreciated:
1.
wiper motor. there are three separate spade terminals at the base of the wiper motor (i've marked them on the photo with a blue, yellow, and green arrow respectively). after reading the factory wiring diagram, it seems that one terminal needs to connect to
ground, one terminal needs to connect to
12v (fused), and one terminal needs to connect to the
wiper switch.
does anyone know which terminals go to where?
2.
the alternator. As i am generally unfamiliar with mini's, i am not sure if this alternator is an externally or internally regulated unit. my guess is that it is internally regulated as i cannot find an external regulator anywhere in the engine bay or under the dash. The alternator was originally connected with two wires (shown with a blue and a yellow arrow in the picture below - central terminal was disconnected). can anyone please let me know which one is the D+ (ign 12v) terminal, and which one is the battery + wire?
3.
headlight switch. there seem to be 5 (?) terminals on the headlight switch. at the moment i have not removed it from the dash panel as i would like to keep it there if possible. can anyone please let me know what terminal (coloured arrow) needs what (ie. constant 12v, dimmer switch connection, etc) on the headlight switch? the factory wiring diagram is not helpful at all because i cannot see any numbered terminals on the hl switch itself. if i have counted incorrectly and there are more/less than 5 terminals, please let me know.
4.
wiper switch. i'm also wondering what needs to connect to what terminal at the wiper switch, but i'm hoping that once i understand the headlight switch i will probably figure out the wiper switch (as they appear to be very similar in design). if anyone could help out i would very much appreciate it, however. the wiper switch is on the far left of the above picture, and seems to have 4 (?) terminals.
5.
headlights/front turn signals. i have this more or less sorted but in my work today i found some
extra wires that were not in the factory wiring diagram. they were:
- red (one at each side)
- black (one at each side)
there are no additional lights in this mini so i am a bit lost as to what is going on. i am loosely assuming that someone in the past has added a ground wire to each of the headlight sockets, so i will try grounding the black wires temporarily when the car has juice again, but if anyone might know what either of these wires might be doing i would love to hear it in advance.
that's enough for now, thank you very much for any help.
charles
