It is currently Thu Aug 14, 2025 8:10 am
 Post subject: cost of motor
PostPosted: Tue Jan 12, 2010 1:07 pm
Hi, any help please what would a 1275 motor out of a 1100s be worth with a coopers 11 stud head. Motor not going as he said the thrust washers are worn allowing crank to much movment and could not get clutch to work properley kept slipping :?: :?:
PostPosted: Tue Jan 12, 2010 1:23 pm
:idea: rebuild it . . . Where in Tassie are you as I may know someone there who can help out shortly if you are interested :wink: :D
 Post subject: motor
PostPosted: Tue Jan 12, 2010 1:25 pm
live in tullah on the west coast
PostPosted: Tue Jan 12, 2010 1:27 pm
Only option. As for it's worth, probably two knobs of goatsh!t because, by the sound of it, good chance the crank is rooted and other related damage.
PostPosted: Tue Jan 12, 2010 1:32 pm
Well I will soon (end of the month) be in Devo if thats any help to you :D
PostPosted: Tue Jan 12, 2010 2:28 pm
Thats a looooooooooooooooooot of endfloat :?
You can still get cranks easy enough though if you need one..... $$$$
Crabby, what's included?
 Post subject: motot
PostPosted: Tue Jan 12, 2010 2:30 pm
it also come with rod change box and 11stud cooper s head
PostPosted: Tue Jan 12, 2010 2:32 pm
Mods rock!
Yes, and a good chance the centre main in the block too, which may mean the block is also US. But the fault description does not make sence.
PostPosted: Tue Jan 12, 2010 2:40 pm
Oh ok, well thats something...
I gotta say,,, I reckon there is more to it than that,,, '
your thrust washers cop the most wear when you're sitting around with your foot on the clutch (because it loads up the crank sideways),,, I don't know if its actually possible to wear your thrusts that much :? I think you could just about remove the thrust washers and the clutch would still engage (you might need to adjust it a bit :lol: :lol: :lol: )
I reckon there is more to this....
Can I ask what the guys asking for?
Endfloat alone is not reason to ditch a 1275 crank.
The thrust faces can be reground, +.030" thrust washers are available, and you can even make a thicker one from solid bronze if you have to (but do put it on the crank pulley side, not the flywheel where the clutch force is).
I have a 1310 motor here with one of these in it.
PostPosted: Tue Jan 12, 2010 2:42 pm
If the thrust surfaces & thrust bearings are that worn then its most likly that the crank & block are throw away, but I doubt that the clutch problem is related to the crank thrusts. The thrust surfaces can be machined/cleaned up and oversize thrusts are available, up to 030. Make sure the head is a genuine S head, rather than a std 1275 head with the extra holes drilled, Mk 1 S heads are numbered AEG163 and have the westlake "W" cast into the top surface behind the thermostat hole, Mk 2 S heads have a part number stamped behind the thermostat hole (12G938). If the crank, block, rods and head are all good/reconditionable condition than its worth up to $1000 in my opinion.
Have a Nice Day.
 Post subject: motor
PostPosted: Tue Jan 12, 2010 2:44 pm
He stated clutch started slipping some time after he ajusted sound like he put thrust washer on wrong have to check it out
PostPosted: Tue Jan 12, 2010 2:53 pm
oi,
12G938 was a 9 stud Morris 1100S head. Mk2 S ones (most) were stamped 12G1805 there.
The only real difference inside the casting was the S had 1/16" bigger inlets and a bit of a clean up.
PostPosted: Tue Jan 12, 2010 3:17 pm
oi,
Im glad someones paying attention. Sorry my mistake :wink:
I know somone who has the wrong head on there Clubman GT then :lol:
Have a Nice Day.
PostPosted: Tue Jan 12, 2010 4:35 pm
850man wrote:
oi,
Meh... it's only a GT.
(dons flameproof suit) :lol:
My GT (was bent, so we wrecked it) had a Mk1 S block and a ported 1100S head. I'm still running that head on my 1360, with an RE282 cam and 1.5 rockers, it kicks arse. :P
Users browsing this forum: Bing [Bot] and 199 guests
