spray paintin .
https://www.ausmini.com/forums/viewtopic.php?f=2&t=60280
Page 1 of 2
Author:  Fiji [ Wed Jan 13, 2010 8:49 pm ]
Post subject:  spray paintin .
hey just spraying the flares on the old girl. using acrylic spray paint nd been getting a bit of orange peeel on 2 of the flares. have been painted b4. thinking i might need to sand pretty far back on these ones. anyone on the peel?
Author:  Phat Kat [ Wed Jan 13, 2010 9:47 pm ]
Post subject:  Re: spray paintin .
I was hoping some one would beat me to this for a change :)
If you already have orange peel, then yes, sanding it all out is the only way to get rid of it.
If you would like to prevent getting it as bad in the future, spray the paint on wetter. Move the gun so that it is only juuuuuuuuust fast enough not to get runs in the paint. This will mean that it cures much flatter... I would also suggest flow coating it to get it flatter and glossier still.
Your flow coat is mixed as 5% colour, 5% clear, 20% retarder thinner and 70% acrylic thinner.
Apply it as described above (just fast enough not to run) and leave it to cure.
The idea of the flow coat is that it takes longer to dry so it has more time to self level AND it is glossier to start with.
It is ideal to use retarder thinner in the flow coat,, but if you don't want to, then just replace it with normal acrylic thinner.
All good? :)
Author:  Davo111 [ Wed Jan 13, 2010 9:52 pm ]
send a PM to trixitrine
Author:  Fiji [ Wed Jan 13, 2010 10:45 pm ]
Post subject:  k
cheers Kat going to sand it back to bare tomor... see what happens with the peel. this is frustrating. afta that i'll see what happens.
thnks
Author:  Phat Kat [ Wed Jan 13, 2010 10:54 pm ]
Post subject:  Re: k
thnks
wo wo wo wo budy, don't go sand crazy on me :)
You only need to sand it till the orange peel is no longer visable... thats all, you don't need to take the paint right off!!!
Ok, this will save you some time. Read carefully
With 1200 grit paper and water, sand the orange peely paint till the peel is no longer visible...
Then buff the paint till a shine appears..
**IF** you sand thru the paint trying to remove the orange peel then sand the whole flare with 600 grit so that you can repaint it..
Does that make more sense that time? :)
Author:  Fiji [ Wed Jan 13, 2010 11:05 pm ]
Post subject:  .
alright i'll see how the 1200 goes,. BUT
i'm slightly more inclined to go a bit further ... 600...
rather go back bit more than do it twice... want her cruising tomorrow night.
.....without flares it's definaely a no go ..... even with em i get hassled bout tyre clearance.
Author:  Phat Kat [ Wed Jan 13, 2010 11:08 pm ]
phew thought I'd missed you :lol:
Oh well, if you just want to sand the orange peel out with the 600 then repaint thats up to you and totally fine. :)
Good luck, show us some photos when your done :)
Author:  Fiji [ Wed Jan 13, 2010 11:14 pm ]
k i will. tempted to get back into it now.... dont have a compressor or anythin so its a can job . does this make for much diff?
hope comes out good.
Author:  Phat Kat [ Wed Jan 13, 2010 11:31 pm ]
nup, no different.
Just remember to spray it on so that it is almost slow enough to run. If its out of a spray can, then they usually use higher opacity paints with are thinner and run easier... so be carefull :)
Oh, and err, you obviously won't be able to flow coat it if you don't have a compressor and gun :wink: :lol:
Author:  miniDave [ Thu Jan 14, 2010 7:52 am ]
Maybe too late now . . . but it pays to use a plastic primer or adhesion promoter on the top of the plastic flare. For a small job you can get a rattle can (is a colourless clear sort of stuff).
If you are stuck using a rattle can for the colour, drop it upright in the sink with some warm water for 10 minutes and it thins the paint and will give less orange peel effect.
Author:  Fiji [ Thu Jan 14, 2010 11:19 am ]
Post subject:  l
still working on the flares.. but howz this a little off topic..
been doing heapa work on the old girl so left my toolbox in the boot last night (live in a unit so there's "apparantly secure" underground parking)
well woke up this morning with a few tools missing .. hammer wire cutters etc etc. (unlocked boot) thought thats weird why not flog the whole box
found them later scattered at the end of the car park .. used to steal someones dirt bike... pretty sure it was a wr450.
sketchy . . .
Author:  marc2131 [ Thu Jan 14, 2010 11:41 am ]
Hi guys,
Most of you guys would have forgotten me, but I've been off line for awhile. Lost my job in Nov but found a new one this month. Hence resumption of the Mini Deluxe restoration and repaint. Yippeeeee!
Regards
marc
Author:  Fiji [ Thu Jan 14, 2010 12:10 pm ]
hey marc start new topic pls
Author:  marc2131 [ Thu Jan 14, 2010 12:19 pm ]
Didnt think it was important enuf to start a new topic. Just wanted to say 'hi' again. its been several months.
Author:  Super-mini [ Thu Jan 14, 2010 3:54 pm ]
hi.
