lead from coil to dizzy how to repair
https://www.ausmini.com/forums/viewtopic.php?f=2&t=60363
Author:  deg [ Sun Jan 17, 2010 12:33 pm ]
Post subject:  lead from coil to dizzy how to repair
Anyone know how i can repair this lead, it has come of in the dizzy?
can you solder it back on?
Author:  GT mowog [ Sun Jan 17, 2010 2:17 pm ]
Generally these ends are crimped on. If it has done this then it can be repaired but it is also usually a sign that the lead has had it's day and needs replacing anyway. A full set of new leads is only about $20 to $25 for OK standard ones.
Author:  Mick [ Sun Jan 17, 2010 2:27 pm ]
Might he be also talking about the low tension one?
The description is a little vague as to which one is broken and how...
Pictures always help.
Author:  GT mowog [ Sun Jan 17, 2010 2:51 pm ]
ErrrUmmm....yeah, your right mick.
Pics please........
Author:  deg [ Sun Jan 17, 2010 3:09 pm ]
Sorry low tension lead.
Author:  GT mowog [ Sun Jan 17, 2010 3:24 pm ]
I take it that it is not a lucas 23 or 25D4 or anything electronic. In the range of 29D4 or 45D4, with a flying type lead.
Yes it can be soldered, however, it can easily be replaced. I guess that the reason it broke in the first place is because the plastic insulation has gone quite hard and become brittle.
