It is currently Tue Aug 19, 2025 12:05 am
PostPosted: Sun Jan 17, 2010 9:43 pm
Hi Everyone,
I'm getting through the items for my roadworthy here and one item was a loose nut on the tie rod end.
Wheel off the ground, move it from left to right, you can the bolt move within the steering arm.
Trying to tighten it, it spins in the joint!
Tried to get multi-grips to hold it (under the rubber jacket) and it can't be gripped to turn the nut.
Any ideas on how to get this tight? Better still, it may be a pain to remove if the steering arm in now worn that joint out.
C&B,
Mark.
PostPosted: Sun Jan 17, 2010 9:53 pm
put a jack under it. :wink:
PostPosted: Sun Jan 17, 2010 10:06 pm
Tempted to try it now at 10p.
Thanks doc. I'll try it tomorrow.
PostPosted: Sun Jan 17, 2010 10:08 pm
As the good Doctor said, get a jack under your tie rod and jack it up into the steering arm, theyre a tapered fit and sometimes they need a bit of persuasion to stay in there :D
PostPosted: Mon Jan 18, 2010 5:41 am
Mods rock!
marks wrote:
Hi Everyone,
C&B,
Mark.
Just before you do do that, just pull it apart again and check that the hole hasn't elongated. Probably be OK, but it'll only take a minute to check. Be sure to use a nyloc nut.
PostPosted: Mon Jan 18, 2010 10:59 am
Thanks Doc. Worked a treat. All done and tyre back on in 10 mins.
I couldn't loosen it for the same reason I couldn't tighten it.
It has removed all movement and I'll re-inspect it in a week or so to make sure.
C&B,
Mark.
Users browsing this forum: Bing [Bot] and 147 guests
