It is currently Mon Jul 21, 2025 6:00 pm
 Post subject: Rear wiring loom
PostPosted: Sun Apr 03, 2005 1:02 pm
Hi: Thanks for the tip about Classic Wiring Looms - I am about to order from them. Is it possible to instal the rear loom without removing the headlining and C pillar cover? Sooner or later the headlining and pillar covers will be replaced, but I don't want to pull it out and do it yet. New wiring is a higher priority. I have in mind slowly pulling out the old loom with the new loom attached to the end to draw it through. Has anyone tried this? Do I pull it through from the back of the car or the front? I am guessing the front half of the rear loom will be thicker than the back half as it should slim down a bit once the interior light wires exit. Its a 1965 round nose body if that makes any difference.
PostPosted: Sun Apr 03, 2005 1:41 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
get a piece of wire like speaker wire and tape it to the loom pull the old loom out gently then reverse the process
makka
Users browsing this forum: Bing [Bot] and 63 guests
