Rear wiring loom https://www.ausmini.com/forums/viewtopic.php?f=2&t=6041 |
Author: | lefty [ Sun Apr 03, 2005 1:02 pm ] |
Post subject: | Rear wiring loom |
Hi: Thanks for the tip about Classic Wiring Looms - I am about to order from them. Is it possible to instal the rear loom without removing the headlining and C pillar cover? Sooner or later the headlining and pillar covers will be replaced, but I don't want to pull it out and do it yet. New wiring is a higher priority. I have in mind slowly pulling out the old loom with the new loom attached to the end to draw it through. Has anyone tried this? Do I pull it through from the back of the car or the front? I am guessing the front half of the rear loom will be thicker than the back half as it should slim down a bit once the interior light wires exit. Its a 1965 round nose body if that makes any difference. |
Author: | min13k [ Sun Apr 03, 2005 1:41 pm ] |
get a piece of wire like speaker wire and tape it to the loom pull the old loom out gently then reverse the process makka |
