Proportioning valves?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=6050 |
Author: | 998_Clubman [ Sun Apr 03, 2005 8:23 pm ] |
Post subject: | Proportioning valves?? |
ok im at the stage where ive got 3m of new steel brake pipe rolled up in my room, well i went down to the wreckers and chopped some brake pipes off a few cars down there, and bent them to shape, only from MS to booster, and back to dual circuit proportioning valve.. and today i bent and cut the new stuff.. ![]() now im a bit confused, i have the standard later? type prop valve on the rear subframe, now with the dual circuit prop valve in the engine bay, do i need to remove the rear valve and put a T peice in there?? and will i have to change the rear wheel cylinders? i cant see running 2 prop valves is normal ![]() thanks ![]() |
Author: | justminis [ Sun Apr 03, 2005 9:04 pm ] |
Forget the proportioning valve in the engine bay, stick with the std prop valve on the rear subframe. Do your brake pipes to suit. |
Author: | 998_Clubman [ Sun Apr 03, 2005 10:05 pm ] |
i just spent $260 getting it reconditioned, its going in ![]() ditch the rear prop valve? anyone? ![]() |
Author: | drmini in aust [ Sun Apr 03, 2005 10:31 pm ] |
Barney is running a dual system from a Clubbie, just has a brass tee on rear subby where the rear limiting valve usually is. ![]() |
Author: | gafmo [ Sun Apr 03, 2005 10:35 pm ] |
T piece from the front section to the two rear's. I was thinking today with the Dual Cuircits..Can you put a Bais control in the system ![]() |
