It is currently Mon Aug 18, 2025 3:12 pm
 Post subject: Problem with the clubman
PostPosted: Sun Jan 24, 2010 12:05 pm
Hi guys,
Finally got the mini out on the road the other night and was all going fine. then... a problem!
when i am driving and rev it past 3000rpm it coughs and splatters like its overfueling or something!! doesnt matter what gear or speed. any suggestions on what it could be? i just have the original single su carby in the car. cheers cam :)
...M I N 1 7 1...
PostPosted: Sun Jan 24, 2010 12:09 pm
Could possibly be plug gaps are way too big, ive seen this b4
PostPosted: Sun Jan 24, 2010 12:21 pm
oh k. i replaced the spark plugs not long ago...wat should the gap be? cheers mate
...M I N 1 7 1...
PostPosted: Sun Jan 24, 2010 6:03 pm
Give Ash some flowers Nick .
Gap should be 0.025" for a ignition system running points (i.e. an original type setup).
All new plugs that you buy these days are set up for electronic ignition systems which provide a much stronger and bigger spark and so it is able to jump a larger distance.
New plugs are gapped to 1.1mm. I always gap my plugs to 0.025" and have never had a problem.
Users browsing this forum: No registered users and 185 guests
