Problem with the clubman https://www.ausmini.com/forums/viewtopic.php?f=2&t=60557 |
Author: | 819cam [ Sun Jan 24, 2010 12:05 pm ] |
Post subject: | Problem with the clubman |
Hi guys, Finally got the mini out on the road the other night and was all going fine. then... a problem! when i am driving and rev it past 3000rpm it coughs and splatters like its overfueling or something!! doesnt matter what gear or speed. any suggestions on what it could be? i just have the original single su carby in the car. cheers cam ![]() |
Author: | mini maxx [ Sun Jan 24, 2010 12:09 pm ] |
Could possibly be plug gaps are way too big, ive seen this b4 |
Author: | 819cam [ Sun Jan 24, 2010 12:21 pm ] |
oh k. i replaced the spark plugs not long ago...wat should the gap be? cheers mate |
Author: | 1018cc [ Sun Jan 24, 2010 6:03 pm ] |
Gap should be 0.025" for a ignition system running points (i.e. an original type setup). All new plugs that you buy these days are set up for electronic ignition systems which provide a much stronger and bigger spark and so it is able to jump a larger distance. New plugs are gapped to 1.1mm. I always gap my plugs to 0.025" and have never had a problem. |
