what do you rev your mini to? (poll)
https://www.ausmini.com/forums/viewtopic.php?f=2&t=6078
Page 1 of 4
Author:  Spaceboy [ Mon Apr 04, 2005 8:34 pm ]
Post subject:  what do you rev your mini to? (poll)
max rpm
Author:  willy [ Mon Apr 04, 2005 8:40 pm ]
Well mine valve bounces at around 6,000 RPM... thats about when i take my foot off the accelerator :)
Author:  Zizzle [ Mon Apr 04, 2005 8:44 pm ]
0 RPM at the moment you insensitive clod! :wink:
Author:  sg [ Mon Apr 04, 2005 8:45 pm ]
5500rpm until i get the weber sorted.... cos atm it won't pull past that, there's just nothing there :oops:
Author:  drmini in aust [ Mon Apr 04, 2005 9:00 pm ]
I used to crank the last one to 8000 on the track, but with the new 1360 I'll try and stop myself at 7500... 8)
But it's got an S crank & rods and a full balance job..
Author:  Lillee [ Mon Apr 04, 2005 9:02 pm ]
No use revving mine over 5000, it goes nowhere after that! at 4500 is about time to change gears in case the people behind me complain about the smoke from unburnt fuel :lol:
Author:  willy [ Mon Apr 04, 2005 9:03 pm ]
Go your hardest Kev! :)
Reckon it will go to 8500 with all the balancing?
Author:  drmini in aust [ Mon Apr 04, 2005 9:06 pm ]
Yeah it probably would but no point. Power passes peak above 7000 anyhow. :wink:
Author:  13secmini [ Mon Apr 04, 2005 9:27 pm ]
limiter is factory set at 7500rpm, has hit it on the dyno a couple of times :shock:
Author:  poeee [ Mon Apr 04, 2005 9:34 pm ]
Mine red lines at 19,800. But only go to 18,900 to improve reliability.
I don't go past 4500. Simple as that.
Author:  IwannaMini [ Mon Apr 04, 2005 9:43 pm ]
running a 998 standard I am lucky to get to the 4000 mark before Mo tells me its time for a different gear.
Author:  Morris 1100 [ Mon Apr 04, 2005 9:43 pm ]
In the 1960s Honda was well known for its racing motorcycles that reved to 18,000 or more. What was not well known was that Honda was fiddling the tacho drives so that the tacho was showing very high.
The other teams thought that Honda was winning because of high revs and tried to build motors that would rev the same. :lol:
Author:  mini_van_1970 [ Mon Apr 04, 2005 9:47 pm ]
No tacho in "The Heinz" at the moment but I think that it would be doing about 5000 to 7000 rpm at full throttle (That is full speed, off the speedo [90mph]) When I get the tacho in I will let people know.
Pat
Author:  sociallydisabled [ Mon Apr 04, 2005 9:53 pm ]
where is the 0rpm option for a few of us. :evil:
Author:  benjamin [ Mon Apr 04, 2005 10:01 pm ]
i never rev mine at all just putt around everywhere
maybe i should see :) mmm one day
Page 1 of 4 All times are UTC + 10 hours
