It is currently Sun Jul 20, 2025 4:15 am
PostPosted: Thu Feb 11, 2010 7:54 am
Hi guys, been a long time sinee i touched my mini's, but going to try and get some done now that I'm on 2nd year apprentice wages :D
First cab off the rank is rear subframe, I pulled it all apart a loooong time ago and its been sitting in a pile since. Rubber cone type. I'm not sure where to start, with all the rubber bits and bearings and jizzle (i've got the pasion, but no know-how)
I found a pic and list of the rear suspension but it just confused me more.
http://www.somerford-mini.co.uk/pdfs/Ca ... erCone.pdf
Any tips as to where i should start rebuilding the suspension?
PostPosted: Fri Feb 12, 2010 9:00 am
Help is only a few keystrokes away....................
Is the subby totally stripped? And what is your budget?
The final result will be comensurate (!) with how much you have to spend on your restoration.
