It is currently Tue Jul 22, 2025 7:08 pm
PostPosted: Thu Feb 11, 2010 1:58 am
any idea's what the length is or a part number..
the one i bought has stretched big time.
any idea's how you adjust the tension properly also?
PostPosted: Thu Feb 11, 2010 8:06 am
Vee belt or ribbed?
PostPosted: Thu Feb 11, 2010 8:21 am
ribbed.. with v..
do they normally stretch?
PostPosted: Thu Feb 11, 2010 8:25 am
I remember having a lot of trouble finding one for my van. I think I ended up using a 590mm belt from AC Delco. Obtained through a generic parts supplier.
I will double check for you tonight.
1964 Morris "Cooper S" Group Nb Racer
1965 Morris 850
ex 1967 Morris Cooper S
ex 1969 Morris Van (Rover SPI running gear)
PostPosted: Thu Feb 11, 2010 9:08 am
NG wrote:
ribbed.. with v..
I mean is it the late flat ribbed one, or the earlier 'normal' V belt (may or may not have teeth).
Most belts will eventually stretch over time, it's normal. It may not be much, but does happen.
PostPosted: Thu Feb 11, 2010 5:06 pm
yeh it is a v belt..
i need the one coming for the water pump of the compressor onto the fan belt type*
i dont need the one coming form the alternator to the compressor... :)
how to do you tension it more.. mines not tensioning.. i can't work it out,
i'm doing it wrong or the belt has stretched.
im sure the belt has stretched as it keeps slipping when i turn the aircon on & i have tensioned the bolt has far up as it will go..
any idea's?
maybe i bought the wrong type of belt
is there a specific type
it just occured to me.. i bought the new one measuring from the old belt thats was all ready stretched..
so i think the new belt has stretched even more, so what would be the best way to work it out with the new belt stretched?
Users browsing this forum: fuzzy-hair-man, timmy201 and 75 guests
