Rover mini aircon compressor belt.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=61015
Author:  NG [ Thu Feb 11, 2010 1:58 am ]
Post subject:  Rover mini aircon compressor belt.
any idea's what the length is or a part number..
the one i bought has stretched big time.
any idea's how you adjust the tension properly also?
Author:  Harley [ Thu Feb 11, 2010 8:06 am ]
Vee belt or ribbed?
Author:  NG [ Thu Feb 11, 2010 8:21 am ]
ribbed.. with v..
do they normally stretch?
Author:  Number86 [ Thu Feb 11, 2010 8:25 am ]
I remember having a lot of trouble finding one for my van. I think I ended up using a 590mm belt from AC Delco. Obtained through a generic parts supplier.
I will double check for you tonight.
Author:  Harley [ Thu Feb 11, 2010 9:08 am ]
NG wrote:
ribbed.. with v..
I mean is it the late flat ribbed one, or the earlier 'normal' V belt (may or may not have teeth).
Most belts will eventually stretch over time, it's normal. It may not be much, but does happen.
Author:  NG [ Thu Feb 11, 2010 5:06 pm ]
yeh it is a v belt..
i need the one coming for the water pump of the compressor onto the fan belt type*
i dont need the one coming form the alternator to the compressor... :)
how to do you tension it more.. mines not tensioning.. i can't work it out,
i'm doing it wrong or the belt has stretched.
im sure the belt has stretched as it keeps slipping when i turn the aircon on & i have tensioned the bolt has far up as it will go..
any idea's?
maybe i bought the wrong type of belt
is there a specific type
it just occured to me.. i bought the new one measuring from the old belt thats was all ready stretched..
so i think the new belt has stretched even more, so what would be the best way to work it out with the new belt stretched?
