Rear subframe rebuild - where to start? https://www.ausmini.com/forums/viewtopic.php?f=2&t=61016 |
Author: | Mattmini [ Thu Feb 11, 2010 7:54 am ] |
Post subject: | Rear subframe rebuild - where to start? |
Hi guys, been a long time sinee i touched my mini's, but going to try and get some done now that I'm on 2nd year apprentice wages :D First cab off the rank is rear subframe, I pulled it all apart a loooong time ago and its been sitting in a pile since. Rubber cone type. I'm not sure where to start, with all the rubber bits and bearings and jizzle (i've got the pasion, but no know-how) I found a pic and list of the rear suspension but it just confused me more. http://www.somerford-mini.co.uk/pdfs/Ca ... erCone.pdf Any tips as to where i should start rebuilding the suspension? |
Author: | AEG163job [ Fri Feb 12, 2010 9:00 am ] |
Help is only a few keystrokes away.................... Is the subby totally stripped? And what is your budget? The final result will be comensurate (!) with how much you have to spend on your restoration. |
