It is currently Sat Jul 19, 2025 6:10 am
 Post subject: clearances
PostPosted: Fri Feb 12, 2010 9:02 pm
what is the effect of too much clearance on idler gear?
and too much clearance on primary gear?
by too much just say 10thou
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Fri Feb 12, 2010 9:07 pm
Too much Idler gear clearance (0.010 or so) will make it noisy, particularly at idle.
On the Primary Gear, do you mean end clearance or bush-to-shaft clearance?
Too much end clearance again will make it noisy and it may weep a bit of oil in to the flywheel and on to the clutch.
Too much bush-to-shaft clearance can give clutch shudder and oil on the clutch and possibly oil leaking past the seal.
PostPosted: Fri Feb 12, 2010 9:10 pm
Too much primary gear bush to shaft clearance (front bush worn) will make it noisy too.
Easiest way to fix this is fit a floating front bush. No machining needed (once you get the old bush out). Available from Karcraft or Minisport SA.
PostPosted: Fri Feb 12, 2010 9:18 pm
i mean end clearance the gap between primary gear and c clip and washer
what would you say too tight clearance on both will cause eg under 3 thou?
77 Leyland Clubman
PostPosted: Fri Feb 12, 2010 9:52 pm
Under .003 on the idler is a real worry. A friend once built a motor which had only .0015" or so clearance cold. When the motor heats up the clearance reduces, he had trouble getting gears.
We had to pull it apart and change a thrust washer.
Under .003 on the primary gear and you won't get a decent oil film on the bronze thrust washer or into the bushes. Could seize up.
Users browsing this forum: Majestic-12 [Bot] and 83 guests
