It is currently Mon Jul 21, 2025 1:11 am
PostPosted: Fri Feb 12, 2010 9:14 pm
Supercharged
where do i get it?
not interested in stuff from spotlight.
PostPosted: Fri Feb 12, 2010 9:49 pm
auto trimmer?
bunnings?
clark rubber?
tim
PostPosted: Sat Feb 13, 2010 7:01 am
Mods rock!
Trimming Vinyls come in backed and non-backed versions. To do something like the lower dash rail, use a non-backed type and lots of swear words...... :shock:
If all your after is a bit to do that, get it from a trimmer.
PostPosted: Sat Feb 13, 2010 8:32 am
'm interested in this too Ms Plum is not quite as well painted inside as she should be
is there a kit available from any of the mini specialists?
I thought some of the Cooper's had it standard but I may have been dreaming
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Sat Feb 13, 2010 8:57 am
John at Mini King should be able to help out and i'm not 100% sure but i seem to recall seeing a kit somewhere , failling that go to an upholsterer and see if they have got something to do the job, they might even have some off-cuts that could get you out of trouble.
Colin.
PostPosted: Sat Feb 13, 2010 6:51 pm
Daleys. 8341 1144.
PostPosted: Sat Feb 13, 2010 8:31 pm
Been there done that!
If you want the original that the Cooper S had.
Its called Madrid.
"Madrid"vinyl (Dash and rail) ~ Fine grain pattern
"Mayfair" vinyl Mk2 pattern seats ~ Little bit courser
Mini King will be the only place who has old new stock. John had run out of all the black stock, I purchased enough green and then got it professionally dyed black.
Hope this helps.
"Boris" - '69 Cooper S Mk 2
PostPosted: Sat Feb 13, 2010 11:49 pm
Supercharged
thanks guys
