It is currently Thu Jul 24, 2025 11:19 am
 Post subject: car back from service
PostPosted: Mon Feb 15, 2010 11:19 am
Hi all just got my mini back from the garage and (im a noobie) i need to get a new R/H lower ball joint and R/H outer CV boot. asap
can someone help me please.
PostPosted: Mon Feb 15, 2010 4:14 pm
whats wrong with the balljoint? cant it be adjusted? I may have a new cv boot . . . will have a look see and let you know.
PostPosted: Tue Feb 16, 2010 9:25 am
He said it was almost all worn out
PostPosted: Tue Feb 16, 2010 11:00 am
Mini ball joints can be adjusted by shimming.
If the ball or cup has worn unevenly the joint will need to be replaced.
New ball joints need to be shimmed correctly, you need to consult you workshop manual, it's pretty straightforward.
You'll really need a ball joint splitter to get them apart as they have a tapered shaft, the old bash with two hammers method works but can do a lot of damage.
Pete
