Clubman Outer Door handle question https://www.ausmini.com/forums/viewtopic.php?f=2&t=61083 |
Author: | MiniKit [ Sun Feb 14, 2010 2:49 pm ] |
Post subject: | Clubman Outer Door handle question |
Is there supposed to be a rubber seal around them? I never took any off when I removed the handles from the door? If there isn't, wouldn't Water enter through the Handle surround? There is a seal available for around the door lock.. |
Author: | Benyni [ Sun Feb 14, 2010 3:22 pm ] |
Post subject: | Yeah? |
Yeah what minikit said? i'm about to start pieceing the puzzle back together. haven't checked parts guide yet! |
Author: | scotta_74 [ Sun Feb 14, 2010 4:05 pm ] |
No there is no gasket but there used to be a black sealant around the edge. |
Author: | MiniKit [ Sun Feb 14, 2010 10:05 pm ] |
Ah HA! Ok, ooer that could be messy, oh well guess I had just be careful then.. |
Author: | Drexxle [ Mon Feb 15, 2010 1:51 pm ] |
put some sealant on the door, let it dry, then fit the handle, and then cut away the excess. |
Author: | watto [ Mon Feb 15, 2010 9:26 pm ] |
I'm pretty sure when I pulled the handles out of mine to have the car repainted that the sealant there was a Mastic type of sealant, not a Silicone sealant. Don't use silicone unless you want it to rust out. The Mastic stuff, from what I understand forms a dry skin on the outside but stays flexible and waterproof on the inside. Anyone else with more info? Cheers, Watto. |
