Quick gasket question
https://www.ausmini.com/forums/viewtopic.php?f=2&t=61132
Author:  Irish Yobbo [ Tue Feb 16, 2010 3:15 pm ]
Post subject:  Quick gasket question
Hi all,
Just started putting on my stage 1 kit from minisport, and found that the inlet gaskets aren't included. And after buying one, I realised that I need two because there was a spacer attached to the old manifold.
I've just cut one out of some gasket cork, but I've noticed that the minisport inlet manifold has a larger hole. I'm using an HS4, and the manifold is also compatible for the HIF44s which need the bigger hole.
Should I just cut the gasket hole a little bigger? No big problem, I'm just not sure what's usually done, and I don't think having the gasket hanging inside the manifold is a good idea.
(Sorry about all the recent topics I've made - I want my mini back on the road!)
Author:  simon k [ Tue Feb 16, 2010 3:27 pm ]
so you're fitting a HS4 (38mm) to a new manifold with a 44mm bore? probably not a good plan - I'd be hunting down a HS6
however
I'd put the 44mm hole gasket on the manifold side of the spacer, and the 38mm hole gasket on the carb side
Author:  Irish Yobbo [ Tue Feb 16, 2010 3:34 pm ]
I bought a stage 1 kit for an HS4 and this was just the one provided. I actually have 6 Hs6 carbs lying around but none of them are in working condition, and I want to keep the fuel economy. For a 998, I understand that an Hs6 would be too much anyway.
By the way, does anyone know what the threaded hole leading into the inlet manifold is for? I know the two pipes at the side are for the water cooling, but it looks like I'll just have to plug up this hole unless it's for something useful.
Author:  mollymoke [ Tue Feb 16, 2010 3:51 pm ]
Post subject:  Hole for brake vac servo
The threaded hole is for your brake vacum connection (if a vac unit is fitted!), otherwise just put a suitable bolt with sealant in to block it off.
