alternater
https://www.ausmini.com/forums/viewtopic.php?f=2&t=61346
Author:  i got a mini [ Thu Feb 25, 2010 8:40 pm ]
Post subject:  alternater
if I have a dead flat battery should my alternator be able to run high beam lights plus head unit plus a amp 75 watt???? Cause it don't or do I need to replace battery ???? I have a multimeter what should I check and what voltage should it be
Author:  i got a mini [ Thu Feb 25, 2010 9:10 pm ]
Author:  i got a mini [ Thu Feb 25, 2010 9:11 pm ]
Author:  meeni [ Thu Feb 25, 2010 9:18 pm ]
with the car running it should be able to.. especially when driving
Author:  Tombo [ Thu Feb 25, 2010 9:20 pm ]
Yes.
Once jump started and running it should be capable of charging the battery and running all standard things. An immense stereo will make it struggle.
To check battery, with car running remove the battery caps and look in at the acid, a few bubbles is fine, any boiling or muddy acid means battery is no good. Also dry is bad.
To check alt use a multimeter across the main terminal of the alt to a good earth (the alt body is good) with a dead battery expect 13 volts rising and with a good battery 13.8 - 14.5 volts.
Hope this helps :wink:
Author:  i got a mini [ Thu Feb 25, 2010 9:37 pm ]
ok cause I recently pulled battery out and one of the cells was dry so is it a battery problem u recon
Author:  mini_mad_matt [ Thu Feb 25, 2010 9:48 pm ]
quite possibly, but you could do a quick check with your multimeter when you get it running, just test the voltage across the battery, with the engine running it should be above 13volts, but over 14.5 or so isnt so good. This is just making sure the alternator is charging ok
Author:  Mick [ Thu Feb 25, 2010 10:29 pm ]
i got a mini wrote:
Ok, because I recently pulled the battery out and one of the cells was dry, so is it a battery problem u(you) reckon?
A dry cell is definitely a problem. It might be time to change it out...but have your alt tested to see it is not overcharging as matt said above..
Author:  awdmoke [ Thu Feb 25, 2010 11:18 pm ]
Most auto electricians will test a battery for free, but in my experience any battery that has had a dry cell is always stuffed.
New battery time. As Mick said, also get the alternator checked too because if it is faulty it will kill a new battery too.
Author:  meeni [ Fri Feb 26, 2010 6:52 am ]
Mick wrote:
quote]
:lol: someone had to do it
Author:  i got a mini [ Sat Feb 27, 2010 7:38 am ]
ok brought a new battery and didn't fix it put multimeter on alternator again and it is basicly stays at 12 volts that mean it no good !?????????
Author:  1310/71 [ Sat Feb 27, 2010 7:54 am ]
What's no good - battery or alternator?
Did you get the alternator checked like people suggested?
It does look like the alternator is not charging based on your (loose) description.
