MiniDna wrote:
Maybe bit strange question for some but I am new. So there it goes;
Is Metro front sub-frame much different than Mini rover?
How can fit one and what sort of mods would require?
Yes, they are very different. The way and location of the mouting points but more importantly, they are quire a bit wider. In short they really won't fit in to a Mini no matter how good you are with a grinder and welder....but why would you want to????? the mini one is considerably stiffer and so will make the handling more predictable.....the hydrogas does work reasonably well in the metro but only because it does have more travel than a mini.
