It is currently Mon Jul 21, 2025 12:02 pm
 Post subject: Stricker lock, plate
PostPosted: Sat Feb 27, 2010 12:45 pm
Hi all,
Went to shut the driver side door yesterday and the striker lock has moved into what looks like the locked position, permanently (refer to images)
http://envyus-htmlemails.com.au/mini/IMG_0329.JPG
http://envyus-htmlemails.com.au/mini/IMG_0330.JPG
So have removed it from the door as I thought I could take the whole mechanism apart (did not realise it was completely sealed). Does this mean I need to purchase a complete replacement or can it be fixed, if so how do I get it apart. I am assuming it must be a spring inside that has broken?
cheers,
Dave
PostPosted: Sat Feb 27, 2010 2:24 pm
Mods rock!
Err...you didn't need to pull it all apart. Put it back together, then hold the handle (either inside or out) open (or have a good looking assistant hold it for you. Then put a screw driver or phillips driver in the latch and push it to the open position, might take a bit of a push. No it's not stuffed.
By gtmowog
PostPosted: Sat Feb 27, 2010 2:25 pm
Poke a screwdriver in the hole behind the catch and while you pull the lever push the catch open with the screwdriver.
Then lube the lock with oil and see if it works properly.
PostPosted: Sat Feb 27, 2010 5:05 pm
this happened to me once. what GT mowog said fixes it. :D
1977 LEYLAND MINI SUNSHINE 'S'
PostPosted: Sun Feb 28, 2010 8:36 am
Well I have learned two lessons today.
1. How to take the door apart.
2. Don't get inpatient, put a post on the forum and wait for a reply (LOL).
Thanks guys, guess what I'm doing this morning?
javascript:emoticon(':roll:')
PostPosted: Sun Feb 28, 2010 8:39 am
One final question to GT mowog, where do you pick up the good looking assistant from to hold my tools !
PostPosted: Sun Feb 28, 2010 3:11 pm
Mods rock!
Like good mini's sometimes you have to look long and hard......
Cheers mate.
PostPosted: Sun Feb 28, 2010 3:22 pm
Sometimes having a good looking assistant is like having 2 good assistants off sick. :lol:
