Steering pinch bolt size? https://www.ausmini.com/forums/viewtopic.php?f=2&t=61360 |
Page 1 of 2 |
Author: | headgasket [ Fri Feb 26, 2010 7:40 pm ] |
Post subject: | Steering pinch bolt size? |
Hi guys, I need to get a new bolt, the old bolt has stripped, even new bolts just slip when you try to do them up. So what length is the bolt, can I just buy a high tensile one from bunnings or do I need a special mini part? The thread is 1/4" I believe. hg. |
Author: | GT mowog [ Fri Feb 26, 2010 7:42 pm ] |
It's 1/4 UNF x 2 1/4 long, grade 5 tensile. I don't think bunnyrabbits would have such an animal. Try a fastener suppliers. I usually use cap head bolts (they're grade 8 or 10). |
Author: | david rosenthal [ Fri Feb 26, 2010 9:24 pm ] |
check the thread in the steering shaft. It may also be partly stripped. when fitting a new bolt make sure that it has a full dia where it fits into shaft not on a threaded section. if the thread has stripped then drill out to 1/4"and fit cap head bolt right thru with a high tensile nut and lock nut . Make sure the slot has a small gap so that when tight it is clamping on spline |
Author: | drmini in aust [ Fri Feb 26, 2010 9:44 pm ] |
david rosenthal wrote: check the thread in the steering shaft. It may also be partly stripped. when fitting a new bolt make sure that it has a full dia where it fits into shaft not on a threaded section.
if the thread has stripped then drill out to 1/4"and fit cap head bolt right thru with a high tensile nut and lock nut . Make sure the slot has a small gap so that when tight it is clamping on spline ??? All my Mini ones (stock) have a 1/4 UNF bolt, and a nut... ![]() |
Author: | blue_deluxe [ Sat Feb 27, 2010 5:46 pm ] |
Yep, pretty much. Stainless steel is brittle, so it doesnt wear very much but snaps without warning. If your using a coarse thread its got less thread area to grip the nut. Im running a high tensile coarse thread in mine, and i just keep on top of it and make it really tight, ill change it when i have to play about with the steering again. |
Author: | GT mowog [ Sat Feb 27, 2010 6:13 pm ] |
Try Auto One, Repco even Supercrap, they have blister paks of various HT bolts, but get rid of that Stainless thing. |
Author: | Morris 1100 [ Sat Feb 27, 2010 6:26 pm ] |
Get rid of the stainless bolt before you kill someone. Do not drive the car. Get the right damn bolt. |
Author: | headgasket [ Sat Feb 27, 2010 6:29 pm ] |
Relax the fiddle sticks up, I'll get it changed. Even if the bloody bolt snaps, the fact that it's there locks into the groove in the splines. It's probably better than it was with the stripped threads. |
Author: | Morris 1100 [ Sat Feb 27, 2010 6:33 pm ] |
headgasket wrote: Relax the fiddle sticks up, I'll get it changed. Even if the bloody bolt snaps, the fact that it's there locks into the groove in the splines. It's probably better than it was with the stripped threads.
When the bolt snaps (because it is going to) the shaft will spread, the splines will jump teeth and you will lose your steering. Fix it before you drive it. You have been warned. |
Author: | 1018cc [ Sat Feb 27, 2010 6:51 pm ] |
I have to agree with M1100. Your steering isn't something you want to take short cuts on! Get the right bolt for it ASAP! |
Author: | drmini in aust [ Sat Feb 27, 2010 7:56 pm ] |
Standard bolt is a Grade 5 hi-tensile. A stock S/S 304 or 316 bolt is nowhere near the same strength. |
Author: | headgasket [ Sun Feb 28, 2010 3:37 pm ] |
Hokai, so today I got in the car and drove 100 km's through twisty back roads at 100km/h to get to supercheap. Unfortunately, a few blocks from supercheap, the pinch bolt snapped as I was turning a corner at Sydney uni and I collected 7 students waiting to cross the road. Then I flipped and rolled under a 18-wheel petrol tanker which was on the other side. The petrol tanker jackknifed and burst into flames before hitting Centrepoint Tower. After 30mins of burning trying to be controlled by the firies, Centrepoint tower collapsed onto westpac and commonwealth bank buildings. At first they thought 9/11 was happening so they grounded all flights, but it turns out it was only a mini with broken steering. Anyways, the bank buildings collapsed and if you are with Westpac or Commbank, your credit card debt is now zero! ![]() ... So I bought new high tensile bolts (with unthreaded shank too!) and installed them in the car. For those wondering, the sources I found say 316 stainless has 75 - 85% the tensile strength of grade 5 (metric 8. ![]() Now, because there is a very slight clunking, only rarely, where do you think that might be coming from? Do I need new tie bar ends? Can I they be tightened? When jacked up, the steering turns lock-to-lock as smooth as a baby's bottom. Also bought some liqui moly MoS2 engine treatment to see if I can reduce my oil burning. Idle hasn't changed, but the smoke when I give it a boot has disappeared. * People who are going to tell me I'm a baby killer needn't bother replying. |
Author: | drmini in aust [ Sun Feb 28, 2010 3:46 pm ] |
My bet is the rack bush (original were felt) in the LH side of rack. Jack the left side up, grab the tierod at the boot and see if it moves fore and aft. If it does it's a rack out job, but not hard to fix. Beware some of the aftermarket racks out there, a reconditioned Oz rack is a better bet. |
Author: | GT mowog [ Sun Feb 28, 2010 3:48 pm ] |
It could be one of a number of items but you did say earlier that the boot on the rack was torn so I'd have a bit of a guess and say the rack needs overhaul. The boot not only keep grit and crud out but also keep the OIL in........without which they do wear quickly............ See also http://www.ausmini.com/forums/viewtopic.php?t=61369 |
