Painting over chrome https://www.ausmini.com/forums/viewtopic.php?f=2&t=61361 |
Page 1 of 2 |
Author: | jester99 [ Fri Feb 26, 2010 8:00 pm ] |
Post subject: | Painting over chrome |
I have a tappet cover that is chrome but has lost a large amount of the chrome and has surface rust all over it. I am thinking of painting over it with the same colour that the rest of the engine will be painted in. Can i paint over the chrome? i am assuming i can sand it, undercoat it and then paint over it. |
Author: | drmini in aust [ Fri Feb 26, 2010 8:06 pm ] |
Sand blast it first or the paint won't stick. |
Author: | micowen [ Fri Feb 26, 2010 8:44 pm ] |
Never done it before, but I guess (and only a guess ![]() Maybe pop a phonecall to a chroming facility. Hope this helps. |
Author: | mini maxx [ Fri Feb 26, 2010 8:55 pm ] |
Just get another rocker cover, got a few here if you want to relieve me of one |
Author: | jester99 [ Fri Feb 26, 2010 9:25 pm ] |
Ok thanks for the help guys. I have a sandblaster so i will just give it a clean up with that and then sand and paint it to suit. Cheers guys. |
Author: | jester99 [ Sun Mar 21, 2010 10:19 pm ] |
had a go today at sandblasting the chrome off the tappet cover. didnt really work. it seems to help remove some of the rust that has taken hold but didnt really do much to the chrome. does anyone know of another way to remove the chrome off the tappet cover? i really want to reuse this tappet cover because it has the breather on the top and i like this particular one. maybe acid dipping would remove the chrome? |
Author: | TheMiniMan [ Sun Mar 21, 2010 10:39 pm ] |
my good mate Stewy is a painter & he`s had success painting chromed covers,,, but he does get them sand blasted & i think they use the industrial strength stuff,,, (heavier/thicker sand maybe?) he then uses an "etch primer" of some sort & does an absolkutely wonderful job,,, they come out absolutely mint when theyre done but i`m not sure what or how he does what "exactly" wheres Phat when you need him??? ![]() |
Author: | DTrain [ Sun Mar 21, 2010 10:52 pm ] |
twisted knot wire wheel |
Author: | jimmyinamini [ Sun Mar 21, 2010 11:48 pm ] |
you need to find a girl by the name of candy with a K i heard she does a great job of decroming towballs ![]() |
Author: | jester99 [ Mon Mar 22, 2010 8:16 am ] |
Dtrain wont that mark the steel or dent it? i have a twisted knot wire wheel and equipment here, do you think i should try that? jimmyinamini Hahahahahahahahaaha! ![]() |
Author: | Timbo [ Mon Mar 22, 2010 9:20 am ] |
The proper way to get chrome off is to take it to a plater and have them strip it, its basically the reverse of plating it. Normally you don't sandblast it off, you just roughen it up and try to get the paint to stick to it. Tim |
Author: | Phat Kat [ Mon Mar 22, 2010 6:12 pm ] |
What media were you using in your sandblaster jester? As matt said there are a multitude of different media, some harsher than others. A wire wheel should work. I would be worried about just keying it and painting it. Reason being that you said that it was rusting through the chrome, so the parent material was already oxidising when it was chromed and wasn't cleaned properly by the platers. In short without the jibber jabber, if you key it and paint it, it won't last long before it starts bubbling off. There are some products available off the shelf at paint shops that under normal circumstances where the chrome is in good nick, will act as a tie coat or sealer for the chrome, you apply it and paint over it. I can't remember what they are called, I've never used them. And to behonest I I know nearly nothing about how they work or anything. . . . Wire wheel, smooth with 240 and paint away. |
Author: | MG Rocket [ Mon Mar 22, 2010 6:24 pm ] |
TheMiniMan wrote: wheres Phat when you need him???
![]() He back!.....Welcome back Phat. |
Author: | Phat Kat [ Mon Mar 22, 2010 6:53 pm ] |
MG Rocket wrote: TheMiniMan wrote: wheres Phat when you need him??? ![]() He back!.....Welcome back Phat. Thanks MG. But don't get used to it. Cheers |
Author: | blue_deluxe [ Mon Mar 22, 2010 7:12 pm ] |
Phat Kat wrote: MG Rocket wrote: TheMiniMan wrote: wheres Phat when you need him??? ![]() He back!.....Welcome back Phat. Thanks MG. But don't get used to it. Cheers That sucks, back to trawling through your old advice. It was nice to have a pro spray painter on here that explained the reactions behind the products. Not just use this, this then that and wipe with that. |
