Flares for a clubman
https://www.ausmini.com/forums/viewtopic.php?f=2&t=61365
Author:  subwayseth [ Fri Feb 26, 2010 9:55 pm ]
Post subject:  Flares for a clubman
hey guys just after the different types of flares that will fit a clubman. It has the "s" guard extensions, spaced type drums & 10x4.5 jelly beans I intend on wrapping in perhaps a falken tyre
Author:  MiniKit [ Fri Feb 26, 2010 10:47 pm ]
How about "S" flares?
Author:  mini maxx [ Fri Feb 26, 2010 10:54 pm ]
Captain obvious is right :lol:
Author:  GT mowog [ Sat Feb 27, 2010 6:18 am ]
John at Mini King them. He would be about the only one who would as these are yet another unique oz part (None of the UK clubbies came factory with flares). John has the original factory moulds so they are as close to a genuine factory one as you will get.
Author:  subwayseth [ Sat Feb 27, 2010 9:49 am ]
thanks fellas,
Captain obvious is right Laughing
thats why i said different types of flares...
Author:  meeni [ Sat Feb 27, 2010 10:30 am ]
im not a fan of the aussie flares... depending on what wheels your using, try some works rally style flares they look alright on clubbies, im putting a set on my one
Author:  MiniKit [ Sat Feb 27, 2010 11:38 pm ]
Post subject:  Re: Flares for a clubman
Well since it has the "S" guard extensions all that would probably fit on there are "S" type flares. There is an extra wide set available, but they would need extra steel welded onto the extensions for them to fit in the normal way, ie small clips that hold both flare and trim to it. The majority of the other flairs look to screw onto the side body work. The size of tyre you are looking at should have no problem fitting within the lines made by the standard "S" guards, if you went wider it may look a little strange. But that's only my opinion, it's your car do what you want.
