It is currently Mon Aug 18, 2025 5:15 am
 Post subject: Spot the problem
PostPosted: Mon Mar 01, 2010 12:00 am
Tomboss Breweros
Heard a funny noise yesterday :?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Mar 01, 2010 12:17 am
wouldthat be the balencer bolt and lock washer chilling down there ? :shock:
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Mar 01, 2010 12:23 am
Tomboss Breweros
Bingo.
I assembled the engine 3 years ago, it's done Hay twice and another khana and now decided to come undone.
Yesterday i drove it 20ks to work which only happens once a week, changed the oil, adjusted the brakes, lubed the nipples and had a little look over, washed it, put it out the front, went to leave and noticed a highly unusual rattle/scrape noise. I'm bloody lucky it happened at work where i have access to a hoist and everything needed to fix it.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Mar 01, 2010 7:24 am
Bin that washer, put Loctite 262 on the bolt threads, torque it up to 75lb/ft and Bob's yer uncle.
Before you do this though, wiggle the harmonic balancer. If it's moving on the key, it and the key should be replaced. I put a bit of Loctite on the crank and key before fitting.
PostPosted: Mon Mar 01, 2010 8:02 am
Once it's all back together again check the clutch overthrow adjustment and also try the crank for movement ;)
PostPosted: Mon Mar 01, 2010 8:31 am
Saw a 998 clubman recently, same prob, but someone had done the bolt back up with one of those impact spanner things that you put on and hit with hammer. they must of hit it a bit hard, they broke the crank.
So now its got an 1100 in it.
Users browsing this forum: No registered users and 117 guests
