Is my 66 Mini the real thing?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=61373
Author:  marc2131 [ Sat Feb 27, 2010 12:12 pm ]
Post subject:  Is my 66 Mini the real thing?
I have always wanted to know if my 66 Mini deluxe is a 'rebirth' job or the real thing ie. the body matching the engine block.
If I provide the Engine No. (on block below spark #1), Engine Prefix (on firewall plate), Body Prefix no., and Body no. (stamped below firewall plate), could someone give me a answer?
My feeling is that it is original, but I am not sure at the moment.
Thanks
Marc
Inner West, Sydney
Author:  mini is my ride [ Sat Feb 27, 2010 1:59 pm ]
hi
I can tell you what the engine's out and I am sure
many other people on ausmini could tell you
Author:  marc2131 [ Sat Feb 27, 2010 2:07 pm ]
Engine no (located under #1 cylinder): 99H834AJ/H1344
Engine prefix no (on firewall plate): 9YA/Ta/H 24501S
Body prefix no: YMA2S2
Body no (stamped below plate): 23528
Author:  marc2131 [ Sat Feb 27, 2010 2:09 pm ]
Forgot to mention - Feb 1966 is stamped on the inside mechanism body of the boot lock.
Author:  Morris 1100 [ Sat Feb 27, 2010 2:18 pm ]
The engine 99H834AJ/H1344 is out of a Leyland Mini from late 1976.
YMA2S2 is a Mini Deluxe.
Car number 23528 would have been made around late 66 or early 67.
The boot lock is only a rough guide to a build date. The last Aussie Minis made in 78 have boot locks stamped 76. :lol:
Author:  marc2131 [ Sun Feb 28, 2010 5:24 pm ]
Thanks for the info Morris 1100. I suspected what you told me but wasnt sure. :(
I have a spare motor which I believe is an 1100 engine. I was told it might be out of an old Morris 1100. The Engine no. is 10Y/Ta/H61856.
Would you be able to identify this motor? Found it in a paddock in Mudgee (central west NSW).
Author:  Morris 1100 [ Sun Feb 28, 2010 5:36 pm ]
Yep, it is a Morris 1100 motor from about 1968. :wink:
Author:  marc2131 [ Sun Feb 28, 2010 5:43 pm ]
I assume it could be dropped directly into a mini with no problems?
Author:  simon k [ Sun Feb 28, 2010 5:52 pm ]
depends if it's a good motor or not..... if you found it in a paddock, there's a good chance it's stuffed
and the gearchange/diff housing is different, so best put on a mini gearbox
Author:  Morris 1100 [ Sun Feb 28, 2010 6:00 pm ]
The diff ratio is awful for anything including a Morris 1100. :lol: It is probably a 3 syncro box. (no syncro on first)
Like Simon said the gear change bolts up differently so you may as well change the the box to a Mini box.
Author:  marc2131 [ Mon Mar 01, 2010 7:57 am ]
OK maybe I will leave the present engine in place.
However are there any suggestions with regards to using bits and pieces from the 68 Morris 1100 engine that can be used with the 998 mini engine? For example are the heads on the 1100 better than the one sitting on the 998?
Marc
Inner West, Sydey
Author:  drmini in aust [ Mon Mar 01, 2010 8:06 am ]
Putting the 202 head on the 998 is worth a couple of HP.
Even more if you add an HS4 and manifold of a 998 Clubby.
Author:  marc2131 [ Mon Mar 01, 2010 8:31 am ]
Thanks Dr,
Will try that. As for the HS4 (from memory, I assume this is the 1 1/2 inch single carb) - already have one fixed to the 998 mini engine. 2 or more HP will be great!! :D
Author:  drmini in aust [ Mon Mar 01, 2010 9:12 am ]
You will see about 4-5HP with both mods.
Even better- deck the 202 head .060" before you fit it to a 998. The C/R will be lower otherwise.
