It is currently Tue Jul 22, 2025 10:59 am
PostPosted: Sun Feb 28, 2010 11:43 am
does anyone know if i will need an engineers report if i'm putting a bonnet bulge into the mini?
my design complies with current ADR's but will i require a cert for vehicle inspections etc?
1962 850,Frog
PostPosted: Sun Feb 28, 2010 12:09 pm
no, you don't need an engineers certificate, just do it.... besides, if it's for your 850 in youur signature, it's pre-ADR, so doesn't matter anyway
PostPosted: Sun Feb 28, 2010 3:44 pm
NSW and ACT have regs on size/height. You would have to check with VicRoads.
PostPosted: Sun Feb 28, 2010 4:22 pm
I know people have been done on modern cars after they cut through the "ribs" of their bonnets to fit scoops. I think so long as it doesn't affect the strength of the bonnet it should be ok.
It probably can't hurt to ring your local engineer just to check with someone who should know for sure.
PostPosted: Sun Feb 28, 2010 4:34 pm
Grab the modification guide from the link below, there are rules about how big it can be restricting visibility and all that, it doesn't need a certificate but you risk a defect if its not within the generous guidelines in the modification guide.
http://www.vicroads.vic.gov.au/Home/SafetyAndRules/SaferVehicles/VehicleDesignStandardsAndAccessories/VehicleStandardsInformaiton.htm
Users browsing this forum: No registered users and 40 guests
