tacho + pulsar dizzy
https://www.ausmini.com/forums/viewtopic.php?f=2&t=61409
Author:  Leighton [ Sun Feb 28, 2010 3:42 pm ]
Post subject:  tacho + pulsar dizzy
how do you wire up a a tachometer to the pulsar dizzy, I just have a standard 3 gauge (clubman) cluster.
Thanks,
Leighton
Author:  drmini in aust [ Sun Feb 28, 2010 3:47 pm ]
I have used a Pulsar dizzy in a Clubby, I wired it as stock and it worked OK.
Can't remember if the tacho was early or later model though.
Author:  Leighton [ Sun Feb 28, 2010 3:54 pm ]
thanks doc, but what wires go where?
Author:  drmini in aust [ Sun Feb 28, 2010 4:08 pm ]
On a Clubby GT, the tacho is wired in series with the power lead to the coil
When fitting a Pulsar dizzy to it, the black/white goes to the coil [+] terminal.
The blue wire goes to the coil's [-] terminal. The wire between the coil [-] and dizzy is removed with the old dizzy.
It is years since I did it.
Pretty sure a Clubby S is the same setup, it would be helpful if Leyland had produced an AUSTRALIAN diagram for it. None of my manuals have one, including the Leyland Black Book.
Author:  Morris 1100 [ Sun Feb 28, 2010 4:17 pm ]
Don't forget that there are two different types of tachos on Clubbies/Leyland Minis. :wink:
Author:  drmini in aust [ Sun Feb 28, 2010 4:18 pm ]
Post above edited after reading manual. :lol:
Yes there are 2 Clubby S tachos, but I think they are both inductive loop.
Early one had banana plugs on the back, as did the GT one.
