It is currently Mon Aug 18, 2025 8:36 am
PostPosted: Tue Mar 02, 2010 7:18 am
Give Ash some flowers Nick .
The rear bush in mine is no longer there so I am wondering if I'll have enough space to get the stepped rod (that goes in the centre) out if I take out the clutch and brake clevis pins and lift the master cylinders up (without disconnecting the brake and clutch lines).
I would like to avoid bleeding the brakes and clutch. So...is this even possible? Will I be able to get enough movement this way?
Cheers, Nick
PostPosted: Tue Mar 02, 2010 7:28 am
Yes you will.
These things are a PITA, I use a bush and a bolt instead.
PostPosted: Tue Mar 02, 2010 7:36 am
Thanks for that Kev. Makes the job alot easier in my mind already :)
PostPosted: Tue Mar 02, 2010 8:33 am
ditto - I'd never seen the stepped bolt until a few years ago when I pulled one out of a car and thought "what a stupid idea that one is" and chucked it over my shoulder
PostPosted: Tue Mar 02, 2010 8:34 am
Ooooh so your S is not original now...:mrgreen:
Something else for the originality police to check for. :wink:
PostPosted: Tue Mar 02, 2010 7:08 pm
Damn, I hope they haven't emptied the bin yet. :shock: 8)
PostPosted: Tue Mar 02, 2010 8:02 pm
don't worry, I have a couple stashed away with the other bits that will be put back on one day
PostPosted: Sat Mar 06, 2010 11:13 am
All done guys. Even easier than what I thought. Plenty of room to get it out and back in (I love having small hands for getting clevis pins & split pins in and out :mrgreen: )
Users browsing this forum: No registered users and 338 guests
