Clutch side engine steady bush https://www.ausmini.com/forums/viewtopic.php?f=2&t=61463 |
Author: | 1018cc [ Tue Mar 02, 2010 7:18 am ] |
Post subject: | Clutch side engine steady bush |
The rear bush in mine is no longer there so I am wondering if I'll have enough space to get the stepped rod (that goes in the centre) out if I take out the clutch and brake clevis pins and lift the master cylinders up (without disconnecting the brake and clutch lines). I would like to avoid bleeding the brakes and clutch. So...is this even possible? Will I be able to get enough movement this way? Cheers, Nick |
Author: | drmini in aust [ Tue Mar 02, 2010 7:28 am ] |
Yes you will. These things are a PITA, I use a bush and a bolt instead. |
Author: | 1018cc [ Tue Mar 02, 2010 7:36 am ] |
Thanks for that Kev. Makes the job alot easier in my mind already ![]() |
Author: | simon k [ Tue Mar 02, 2010 8:33 am ] |
drmini in aust wrote: I use a bush and a bolt instead.
ditto - I'd never seen the stepped bolt until a few years ago when I pulled one out of a car and thought "what a stupid idea that one is" and chucked it over my shoulder |
Author: | drmini in aust [ Tue Mar 02, 2010 8:34 am ] |
simon k wrote: drmini in aust wrote: I use a bush and a bolt instead. ditto - I'd never seen the stepped bolt until a few years ago when I pulled one out of a car and thought "what a stupid idea that one is" and chucked it over my shoulder Ooooh so your S is not original now... ![]() Something else for the originality police to check for. ![]() |
Author: | Morris 1100 [ Tue Mar 02, 2010 7:08 pm ] |
drmini in aust wrote: simon k wrote: drmini in aust wrote: I use a bush and a bolt instead. ditto - I'd never seen the stepped bolt until a few years ago when I pulled one out of a car and thought "what a stupid idea that one is" and chucked it over my shoulder Ooooh so your S is not original now... ![]() Something else for the originality police to check for. ![]() Damn, I hope they haven't emptied the bin yet. ![]() ![]() |
Author: | simon k [ Tue Mar 02, 2010 8:02 pm ] |
Morris 1100 wrote: drmini in aust wrote: simon k wrote: drmini in aust wrote: I use a bush and a bolt instead. ditto - I'd never seen the stepped bolt until a few years ago when I pulled one out of a car and thought "what a stupid idea that one is" and chucked it over my shoulder Ooooh so your S is not original now... ![]() Something else for the originality police to check for. ![]() Damn, I hope they haven't emptied the bin yet. ![]() ![]() don't worry, I have a couple stashed away with the other bits that will be put back on one day |
Author: | 1018cc [ Sat Mar 06, 2010 11:13 am ] |
All done guys. Even easier than what I thought. Plenty of room to get it out and back in (I love having small hands for getting clevis pins & split pins in and out ![]() |
