Dirty work https://www.ausmini.com/forums/viewtopic.php?f=2&t=61509 |
Page 1 of 4 |
Author: | Kennomini [ Thu Mar 04, 2010 7:15 pm ] |
Post subject: | Dirty work |
After reading a few UK based mags and stuff it seems the Brits are mad keen on wearing latex gloves while working on their cars. So who here wears gloves while working on their car? |
Author: | Mick [ Thu Mar 04, 2010 7:17 pm ] |
Only if I have a need to prevent friday fingers, or I'm washing bits up in the parts washer.. |
Author: | 1071 [ Thu Mar 04, 2010 7:18 pm ] |
It is a bit worrying at times when you stick your gloved hands in stuff and then find after ten minutes that the gloves have dissolved....javascript:emoticon(':shock:') Cheers, Ian |
Author: | sports850 [ Thu Mar 04, 2010 7:19 pm ] |
Nope , never used them but i have really good hand cleaner ![]() |
Author: | Morris 1100 [ Thu Mar 04, 2010 7:34 pm ] |
I have tried gloves but I can't get good ones. Any clues on where to buy good ones? |
Author: | gafmo [ Thu Mar 04, 2010 7:44 pm ] |
Gloves for me..no chance..I like to feel what i'm doing. but I do use sugar soap or cloths washing powered. Keep nails short but in saying that I walk around in GR's work shop in bare feet but have to wear steal caps 8-4 at work . Get a good hand cleaning product that is good for your hands and get a ratty tatty towel for for use in the garage |
Author: | ryan [ Thu Mar 04, 2010 7:45 pm ] |
I haven't done this. But I'd imagine it would save a lot of scrubbing. However most latex gloves aren't very good. You would need quality and then it gets expensive. as morris said, any advice on brands etc? |
Author: | GT mowog [ Thu Mar 04, 2010 7:45 pm ] |
Morris 1100 wrote: I have tried gloves but I can't get good ones. Any clues on where to buy good ones?
I did get some from a company called Livingstones. They do scientific supplies. The gloves were Oil Resistant and did last quite well while still offering some feel. They were very expensive (and this supplier is cheap for most stuff). I just use barrier cream these days. |
Author: | Circus_Maximus [ Thu Mar 04, 2010 8:00 pm ] |
I use a combination, disposable vinyl examination gloves as the inner pair with white cotton (available from woollies) as the outers. I still get good "feel" and the cotton stops the vinyl gloves from being easily torn. Does not matter if the cotton gets soaked in oil and grease, the vinyl inners stop the fingers getting dirty. They do sweat a little but is not too much, and cheap enough to be disposable. Latex is not so good as it can set off a dermatitus reaction in some people and is not as resistant to solvents. |
Author: | Bubbacluby [ Thu Mar 04, 2010 8:11 pm ] |
i heard about a local mechanic that did this i thought it was a crack up. Nope never use them, Nothing a bit of mums radiant washing power cant fix. ABSOLUTELY BRILLIANT!!!. |
Author: | osk80 [ Thu Mar 04, 2010 8:22 pm ] |
I'm a plumber and these gloves are a part of every day life.I've tryed useing them during my mini rebuild and maintenance and found it easier at times' exspecialy when the phone rings.But the boss is in the process of changing to barrier cream becose of the expence of the gloves. |
Author: | Tombo [ Thu Mar 04, 2010 8:25 pm ] |
I use them, with experience you naturally make them last longer. Brake fluid makes my hands sore so they are really good for that. Cars are filthy things ![]() |
Author: | Asphalt [ Thu Mar 04, 2010 8:46 pm ] |
Latex gloves are no good... They'r to fragile for most work... I use cotton wool gloves. Takes a bit to get used too, but then they'r fine. They let oil through, though. But the amount of thin grease and oil that gets through washes off realy easy ![]() Cheers, Jan |
Author: | albino235 [ Thu Mar 04, 2010 8:52 pm ] |
This really is a can of worms... Some components of oils, greases, fuels and solvents are know carcinogens, your skin is porous and so it is best to avoid direct contact, the labels usually say something to that effect. I value my health in the long term and so I wear 2 pairs of cheap latex gloves and just swap the outer pair when ever they get damaged or I switch from a messy to clean job... |
Author: | 850 GT [ Thu Mar 04, 2010 9:13 pm ] |
I keep old socks, realy good when you pull an engine down. just undo all bolts with air spanner, then pick up with old sock on hand, very good for head bolts etc. when you are finished just chuck em!! |
Page 1 of 4 | All times are UTC + 10 hours |
