998 Cam Vs 1098 Cam https://www.ausmini.com/forums/viewtopic.php?f=2&t=61534 |
Author: | MiniKit [ Fri Mar 05, 2010 11:50 pm ] |
Post subject: | 998 Cam Vs 1098 Cam |
Are they supposed to be the same (standard).... Or..... Like mine, the one that I have pulled out of my 998 seems to have a bigger lift with a longer duration (only measured with verniers because that's all I got). I'm guessing if the 998 cam does have the higher, longer lift then that would be the one to use if I decide to stroke the motor. Obvious yes? It's late and I'm tired and I'm not really sure which way is up right now. So help please. Thanks esteemed mini peoples. ![]() |
Author: | drmini in aust [ Sat Mar 06, 2010 7:50 am ] |
All A series 998 cams (except the 998 Cooper one) have only .285" lift at valve. 1098 cams have .312", also more duration. The only good use for a 998 cam is for regrinding to something decent. ![]() If your 998 one has more lift, it may have been reground already. |
Author: | MiniKit [ Sat Mar 06, 2010 10:17 am ] |
Thankyou. |
