need help in the wollongong area
https://www.ausmini.com/forums/viewtopic.php?f=2&t=61597
Author:  andbat [ Mon Mar 08, 2010 8:00 am ]
Post subject:  need help in the wollongong area
i've been trying to remove the hose between the slave and master cylinder with a 11/16 and 5/8 but failing. if anyone is able to come round and help me out it'd be great.
also is the hose a specialist part?
pm me.
Author:  mini is my ride [ Mon Mar 08, 2010 11:14 am ]
wow some place I do know,
I am a novice but willing to give you a hand
Author:  DTrain [ Mon Mar 08, 2010 11:47 am ]
use a shifting spanner? might also need some wd40 if it hasnt been changed in a while
Author:  peterw [ Mon Mar 08, 2010 12:44 pm ]
Assuming you mean the flexible line, you need to unscrew the solid line that comes from the MC. It screws into the flexible line. Then undo the lock nut that holds the flexible hose in the bracket on the firewall. Once the flexible hose is free that end you should be able to undo it from the slave and take it off.
If my memory has this a bit wrong I'm sure someone will chime in with a correction.
Pete
Author:  850 GT [ Mon Mar 08, 2010 2:18 pm ]
Sounds right to me.
Have fun!
Author:  WiLo [ Mon Mar 08, 2010 2:20 pm ]
flex line has now been changed, couldnt bleed the clutch seeing as andy is at uni.
as i said in the sms see if you can bleed it and get good pedal feel if not order a new flex line from one of the online places and get a new hardline from one of the local places(ive had one done at reliance brakes in fairy meadow and only cost $10, compared to the $30 that some places are charging online.
although id suggest getting the single piece braided line that minisport have its a bit pricey so i doubt youll want to go that option
Author:  ryan [ Mon Mar 08, 2010 3:31 pm ]
your a good man Scott,
If I wasn't at work I would of come around and helped. I tried ringing Andy 15mins ago, I guess he is still at uni
:roll:
Author:  WiLo [ Mon Mar 08, 2010 4:06 pm ]
dont give me praise yet, unsure if it is fixed or not.
people say clubbys have room in the engine bay i disagree, wouldve taken me half hour to do on my car but took a while because of the brake booster and starter solenoid being in the way.
Author:  Morris 1100 [ Mon Mar 08, 2010 4:18 pm ]
There is a couple of tricks to bleeding the clutch on your own.
My way is to use something to hold the pedal down while I undo the bleed screw. I use either a bar or screwdriver jammed under the brake pedal and over the clutch pedal.
Or..
A block of wood on the clutch pedal and against the front of the drivers seat.
It may take a few trip from inside the car to under the bonnet but you will get there in the end.
Author:  andbat [ Mon Mar 08, 2010 10:51 pm ]
thanks a sh!te load WiLo. i'll give it a bleed and test tomorrow arvo after uni. you working round then? also i'll buy some credit so i can communicate again.
sorry i had to reject your call ryan, you guessed it, i was at uni in a quiet tutorial.
Author:  ryan [ Tue Mar 09, 2010 4:40 pm ]
I popped around to andrews this arvo,
We bled the clutch and got it all sorted. Scott wi-lo pulled up just as we were about to test it.
It all seems fine now. andrew thinks it feels a little softer than before. To me it feels like normal pedal. Main thing is it is all working.
:D
