There were actually 3 (Three) different master cyl reservoirs avaliable throughout the plastic res era,,, Girlock (rare),,, PBR ,,,& Lockheed (Most common)
all were the same dimentions/shape etc,,, just different logos moulded into them
I`ve tried , but can`t "nut-out" any change point for them, i believe that the lockheed was the std original part , & both Girlock & PBR tried to bite off a piece of the pie by introducing their own later on.
i had the Lockheed type made & yes the res has LockReed on it but the lid i kept as per original
The std original Cooper "S" tin res type cyls are a different kettle of fish to the GT plastic res type cyls
EDIT-> Oh & the new reservoirs that i had made were almost going to have "Look-Read" on them all,,, but they wanted way too much money to change them soo much, i just had the "H" changed to the "R"
They are also made from """WAY""" better material than the originals,--> they are all starting to break up quite bad these days so i used the very latest & greatest quality material for the job.
nothing but the best for all you guys
2nd EDIT--> Oh & i have some 2nd hand cyls here if anyone needs some & of course i have plenty of brand new reservoirs , Repair kits are still avaliable (I do carry stock of those too) & i would have the cyls sleaved with stainless steel so they last for ever.
i would fit .75" for the clutch (with no "Slow-Return-Valve) ,,, & .7" for the brake (With the "Slow-Return-Valve),,, that simply is the best combination.
