Rubber washer & steering rack
https://www.ausmini.com/forums/viewtopic.php?f=2&t=61620
Author:  andyd718 [ Mon Mar 08, 2010 9:58 pm ]
Post subject:  Rubber washer & steering rack
Does anyone know if there is supposed to be a rubber washer/seal that goes between the steering rack and the shell? I can't remember there being one but it looks like something's supposed to be there...
Author:  TheMiniMan [ Mon Mar 08, 2010 10:59 pm ]
it was a felt originally
Author:  AEG163job [ Mon Mar 08, 2010 11:06 pm ]
Damn hard to find in parts books. Basically, its flat spongey round seal about 1 1/2" in diameter which stops the dirt & water entering. If you can get hold of some soft spongey rubber about 5 mm thick so it compresses when you bolt up the rack, that should do the trick.
Author:  TheMiniMan [ Mon Mar 08, 2010 11:09 pm ]
cut up an old thong
No,,, not "That" type of thong you dirty old men :-)
Author:  GT mowog [ Tue Mar 09, 2010 5:49 am ]
P/N 21A30, should cost you all of about $1.50. They are 12mm thick when new and a soft foam rubber, but when they're squashed they don't come back. If you make one from a thong, don't cut the centre hole too small, you don't want that tight at all.
Oh and panties are way better than thongs..................
Author:  EST-071 [ Tue Mar 09, 2010 8:08 pm ]
Last time I replaced one I used an old mouse pad and cut one to fit.
Cheers Pete
Author:  micowen [ Tue Mar 09, 2010 8:24 pm ]
doogie once mentioned that he uses the bottom off a stubby cooler!
Every blokes got a collection of them laying around! :lol:
