It is currently Tue Aug 05, 2025 12:06 pm
 Post subject: lapping of the valves
PostPosted: Tue Jul 10, 2007 9:00 pm
hi can someone explain to me what exactly is lapping of the vavles and is it an expensive thing how much appros does it cost and if you dont do it what are the effects?
PostPosted: Tue Jul 10, 2007 9:13 pm
I used to work in an engine reco shop years ago...
These days most reco shops just reface the valves and recut the seats.
The 45° valve angle and seat angle are about 1° diffent to each other.
They are supposed to seat themselves without any lapping. So-called `synchro seating'.
That said, I've seen enough dodgy valve and seat cutting that I still lap them in by hand afterwards, to be sure they are concentric.
This is done with a lapping stick (wooden dowel with suction cup on end) and some fine valve lapping paste.
You put a light smear of paste on the valve face in about 6 spots, drop it into the seat then use the stick in a to and for motion, give it about 10 or so oscillations.
Then lift valve out, wipe it and the seat and inspect both. Repeat if necessary. When you have a dull grey contact area 1mm or more wide on both, move on to the next one.
If the contact is not quite all around, either use some coarse paste to give metal removal, or preferably take the head back to who did it and have a whinge... :x
Try not to get any paste and grit on the valve stems...... :shock:
When finished degrease head to get all the grit off the seats, and the valves. Then assemble.
Last edited by drmini in aust on Tue Jul 10, 2007 9:15 pm, edited 1 time in total.
PostPosted: Tue Jul 10, 2007 9:14 pm
Something you can do yourself if you have the time/patience.
Valves and seats should be ground/cut first. Lapping is the "fine tuning" part.
I use bearing blue to firstly check valves are seating properly. Excessive lapping to get valves seating properly is a no no.
Also, your guides need to be in good nick, so the order of the day is 1, replace guides, 2 have valves/seats cut properly by experts, 3 final lapping in.
