Please don`t be confused Nick
sooo many people talk about HP as if it were soooo easy to make over 100hp
well it`s not that easy to make over 100hp """AT THE WHEELS""" in a road going mini
"""IF""" someone tells you that they actually have over 100hp """AT THE WHEELS""" in their """ROAD""" mini then it will be a rough, lumpy Full race type engine, most likely running on AV-Gas & probably shouldn`t be on the road anyways
an 100Hp "At The Engine" mini will have approx 75-80-ish (give or take) at the wheels
hence the std cooper "S" having approx 70hp at the engine will have about 45 at the wheels,,, (& that`s a good one)
Turbo &/or supercharged minis are a different kettle of fish,,, they can make good grunt & still be quite smooth-ish
"Torque" (however) is a whole different ball game,,, this is the stuff we really want !!!!!!!!
Power - to- weight ratio is another "easilly" miss-interpreted "feeling"
jump in my hillclimb car & you`ll feel a whole bunch of wonderful things,,, lots of HP (138 at the wheels) also a heap of torque but not dramtic amounts,,, but most importantly you will feel the "Power-to-weight" ratio is brilliant & will make the car feel more powerful than it really is
your wagon will need "Torque",,, It`s a heavy mini ... HP is just a figure worked out from an equation between the torque (Turning power) & the revs per minute
High HP figure """at lower revs""" basically means lots more torque than another engine making the same-ish HP at a higher rev
& also please understand that there are soooo many dynos out there that read way higher than others,,, it`s a big major motha of a pet hate of mine that people can happilly present their HP figure willy-nilly with no other comparison to directly relate it to the "real-world"
be very carefull Nick,,, it`s a very tricky subject that soo many people don`t really understand totally & yet they will tell you they know... Just look at my sig
