Tasman Wheel nuts? https://www.ausmini.com/forums/viewtopic.php?f=2&t=61712 |
Author: | andytas [ Fri Mar 12, 2010 3:25 pm ] |
Post subject: | Tasman Wheel nuts? |
Does anyone know what wheel nuts Tasman wheels take? Are they the same as either Mamba's? Minilte? or Contessa's? |
Author: | drmini in aust [ Fri Mar 12, 2010 3:28 pm ] |
Same as Dunlops I think. They are a shouldered nut and a flat washer. [edit] I just tried a Contessa nut in a borrowed Tasman, it's way too small. |
Author: | GT mowog [ Fri Mar 12, 2010 3:34 pm ] |
Post subject: | Re: Tasman Wheel nuts? |
andytas wrote: Does anyone know what wheel nuts Tasman wheels take? Are they the same as either Mamba's? Minilte? or Contessa's?
It's actually none of these. I had a heap made last year. I'll measure one and let you know what the sizes are. I'm actually looking for some centre caps that fitt and look nice, not necessily tazmans. |
Author: | andytas [ Fri Mar 12, 2010 4:10 pm ] |
Please pass on those details when you ca. Will the person who made them up for you be willing to do another run? |
Author: | doogie [ Fri Mar 12, 2010 4:51 pm ] |
You can buy nuts & washer to suit these wheels from Mini spares at Padstow. 02 9774 3366 Doogie |
Author: | GT mowog [ Fri Mar 12, 2010 5:24 pm ] |
doogie wrote: You can buy nuts & washer to suit these wheels from Mini spares at Padstow.
02 9774 3366 Doogie When I enquired they didn't have new ones. I was a case of ramaging through what they had a find some that were OK. No thanks, unless they now have new ones. |
Author: | GT mowog [ Sat Mar 13, 2010 5:00 pm ] |
The plain shank is 5/8" diameter and is 3/4" long (on the plain shank), however they also use a plain flat washer 5/8" ID x 7/8" OD x 0.120" thick. The AF Size is 11/16" (to keep them original) and of course the thread is 3/8 UNF. |
Author: | Tadhg [ Sun Mar 14, 2010 1:01 am ] |
Which Tasmans are we talking about..? Mark I, or Mark II..? ![]() ![]() ![]() ![]() |
Author: | GT mowog [ Sun Mar 14, 2010 5:29 am ] |
As far as I am aware, from new, all Tasmans used a washer;- Tasman MK I's ![]() By gtmowog Tasman MK II's ![]() By gtmowog (Thanks to my good friend Jan for the pics) I can only guess that at some stage someone fitted tapered nuts to them. It was in fact quite common for people who bought these wheels second had (and without nuts) to use the standard road wheel nut. I have seen quite a few fitted that way. Of course once the taper is there you need to have the wheel repaired to get rid of it. It is not a good idea to use tapered nuts on these wheels as they can fail. They did actually gain a bad reputation, for failing (centres breaking out), but this was not on the 10" rims for Minis, only the 12" and bigger as fitted to Escorts. I have had (and still got) lots and lots of Tasmans MK I's and MK II's over the years (I've got 6 sets of 5 in the shed right now) and they all take washers. I just love 'em, they look particularly good on a Clubbie I recon. |
