Replacing gauges
https://www.ausmini.com/forums/viewtopic.php?f=2&t=61736
Author:  jethro [ Sat Mar 13, 2010 3:14 pm ]
Post subject:  Replacing gauges
Hi Guys, can anyone help me out with this ??When I renew the interior of my 78 Leyland S (998 ) Do I have to keep the same 3 gauge instrument binnacle or can i replace speedo as well as change tacho so in effect I am changing the dash panel completely ??I know with the speedo the cable needs to be the same end going into the motor/gbox. If I fit water temp and oil press gauges are the outlets already there ??
Geoff
Author:  GT mowog [ Sat Mar 13, 2010 5:44 pm ]
They are almost all interchangable.
Differences if you are buying a second hand set;-
Speedo Cable - early ones were screw on and about 1977 they changed to a clip on.
Tacho connections - the early ones used a RVI type Tacho which has a 'loop in and loop out' type connection and the later ones were a RVC type connection which just had a single pick up from the points. The wiring Harness in your car will suit only the RVC type Tacho (although it's not difficult to modify).
Author:  jethro [ Sat Mar 13, 2010 7:27 pm ]
so GT mowog, I won`t be able to change over completely to say splitfire gauges !!!!
Geoff
Author:  GT mowog [ Sat Mar 13, 2010 7:35 pm ]
Geoff
I didn't realise from your first post that you wanted something custom !
Yes, you could put spitfire gauges in, however the Air Speed Gauge will need significant re-calibration and you won't have to worry about screw on or clip on speed cables.
You'll also need a different distributor with a mechanical tacho take off!
It shouldn't be too difficult to put different gauges in. If they are non-smiths ones, you'll have to (preferably) get matching senders for fuel and temp, but that's not a 'show stopper'. I would think it more difficult to tastefully mount them actually.
<EDIT> for an oil presure gauge, there is presently a switch in the block near the distributor. You can either swap that for a gauge sender, or put a tee in so you can have both. Not a big deal.
Author:  jethro [ Sat Mar 13, 2010 8:38 pm ]
if it is too much trouble I may stick to smiths gauges. I thought a different look might be ok though. What is an air speed gauge.
Author:  Harley [ Sat Mar 13, 2010 9:38 pm ]
Time and money dependent ofcourse, there is no limit to what gauges you can fit into a mini, or any car for that matter.
:D
Author:  GT mowog [ Sun Mar 14, 2010 5:34 am ]
Well, think of it this way;
Your Mini travels on the ground so it has a (ground ) speed gauge, more commonly known as a speedo.
A Spitfire on the other hand.........
Author:  superSeven [ Sun Mar 14, 2010 5:47 am ]
SPLITFIRE
even if he MEANT Spitfire, I think triumph spitfire gauges would be a more likely candidate than a Supermarine Spitfire..... and I don't think Triumph spitfires can actually leave the ground... ;)
Author:  GT mowog [ Sun Mar 14, 2010 6:28 am ]
superSeven wrote:
SPLITFIRE
My bad (I should put my glasses on a bit more often). I did see something (somewhere) where someone was selling Aircraft Gauges modified for Auto use.
(Triumph in engineering stupidity) Where there is a will................ :wink:
