New Master Cylinders https://www.ausmini.com/forums/viewtopic.php?f=2&t=61740 |
Author: | adamstuart [ Sat Mar 13, 2010 5:57 pm ] |
Post subject: | New Master Cylinders |
Saw a thread a while back where someone mentioned buying new master cylinders. Tried searching, no cigar. Can anyone point me in the direction of the thread or tell me the price and where they got them? Need a master clutch cylinder to match 77 clubby |
Author: | DTrain [ Sat Mar 13, 2010 5:59 pm ] |
http://classicmotoring.net.au/cmos/ http://www.minisport.com.au/ http://www.minis.com.au/minis/catalog/index.php http://www.karcraft.com.au/home.php |
Author: | GT mowog [ Sat Mar 13, 2010 6:01 pm ] |
It might appear not related, but this is. Has your clubbie got tandem brakes? |
Author: | Wombat [ Sat Mar 13, 2010 6:04 pm ] |
I purchased new tin can MCs from the UK ( and the $ was not as good as now) $332 including freight of $180 Local suppliers were $660 plus freight. But then when I came to buy my RC40 exhaust it was the other way round. So moral is check your prices ![]() |
Author: | GT mowog [ Sat Mar 13, 2010 6:15 pm ] |
Wombat wrote: I purchased new tin can MCs from the UK ( and the $ was not as good as now) $332 including freight of $180 Local suppliers were $660 plus freight.
Author: | Drexxle [ Sat Mar 13, 2010 6:49 pm ] |
i bought some new ones off a supplier in sydney, and low and behold the rubbers inside needed replacing, so i dont know how long they had been sitting on the shelf for. |
Author: | Morris 1100 [ Sat Mar 13, 2010 9:40 pm ] |
Drexxle wrote: i bought some new ones off a supplier in sydney, and low and behold the rubbers inside needed replacing, so i dont know how long they had been sitting on the shelf for.
You should always check the rubbers in new brake parts. They are sometimes bad from new. I have also had new wheel cylinders with casting faults. |
Author: | TheMiniMan [ Sat Mar 13, 2010 11:50 pm ] |
years ago we bought a new set of rear cyls,,, still sealed in the plastic & sealed in the box took em out & was about to fit them,,, one of em diddn`t even have a seal fitted to the piston ![]() true !!!! |
Author: | drmini in aust [ Sun Mar 14, 2010 8:25 am ] |
I had seals go on a brand new `Brake Engineering' (Italian made) Cooper S rear wheel cylinder in 12 months. Replaced the pistons and seals with another new pair (quicker than swapping the cylinder). The other side is still fine, 2 years later. Another time, Gafmo fitted a brand new clutch slave cylinder. 6 months later it leaked, so I put a new Oz seal in it. No more probs. I believe lots of the seals that are coming in now are second rate... ![]() |
